Jostrans68
Rarity 1st 72 c20 frame was a 402 auto I have all the factory exhaust brackets there are 2 midway by cab 2 at the center support I will have to look but I think 2 at differential and 2 behind wheels. What are these worth?
it still has the factory big block mounts Clamshell style 1972 value? I am keeping the rear end its is a 3.54 dana 60 8 lug I will have a good set of the 3/4 ton trailing arms to sell and auto cross member I will post some pic tommorow any idea on above values? i need opinions thanks Jack ![]()
![]() former 67-72 now with a 96 silverado |
its all about the +6 inches
The motor mounts are cheap, the towers they bolt to are worth more than the rest of your chassis there.
trailing arms $50=$100 pair
frame you may have to pay somebody to take it
Jostrans68
Still has the towers that the mount goes to on frame any Idea on value of those?
![]() former 67-72 now with a 96 silverado Last edited by jostrans68; 09-01-2005 at 08:32 AM. |
The exhaust brackets are worth as much as the towers.I`d put them as a package for,like,$100?Maybe more?Someone wanting to go sb-bb original-style would want these bad.The trailing arms are common and cdowns is right.They`re the same as 1/2t.Now,about that rear....
3/4 ton trailing arms are beefier than 1/3 ton arms...good up grade.
I've seen the motor mount stands go for 100 bucks alone. |
Jostrans68
I took of diff cover tonite and it looks pristine, drums are good still had factory tag on it showing 3.54 gears might help on gas a bit? looking for info if any on rear disc conv for 8 lug thanks Jack
