09-01-2005, 11:20 AM | #1 |
700r4 trans
what will i have to do to put a 700 trans in my 68 4x4 with 205 transfer case? do you have to cut driveshafts ect?????????????/
Thanks Scott |
09-01-2005, 01:50 PM | #2 |
You can do it without cutting driveshaft, but you have to relocate the engine crossmember. You will also need to get an new tailshaft from advance adapters or run a spacer between the tranny and the transfer case. You will need a TV cable to hook the tranny to your carb as well. I am sure I am missing a few things. I would tell you to use the search function but for some reason they have it turned off.
Mike
Mike Redpath |
09-04-2005, 06:09 PM | #3 |
the 700 is a longer trans. so putting the spacer and moving the crossmember will make the rear driveshaft shorter would it not?i checked the 350 and the 700 .the 700case is 2.5 inch. longer..
09-05-2005, 03:50 AM | #4 |
Senoir Member
Check this thread, it also lists another thread in it. There are several more around also.
http://67-72chevytrucks.com/vboard/s....php3?t=145568
67 Chevy, Small back glass, Factory 4WD, Factory Shortbed, Factory V8, Lifted 4" 70 GMC Sierra Grande, Factory Shortbed, Factory 402/400 turbo, Super Custom Interior. Numbers matching with SPID & Build Sheet. 68K Original Miles. Restored 2010 70 GMC Restoration Pictures http://67-72chevytrucks.com/gallery/...00&ppuser=4424 |
09-05-2005, 01:53 PM | #5 | |
Mike
Mike Redpath |
09-05-2005, 07:00 PM | #6 | |
09-05-2005, 09:18 PM | #7 |
Senoir Member
git-r-stuck, Welcome to the board!! You won't find a better place. No, I have not changed the trannie yet. I am considering putting a 454 & 700r4 in my 67 K10. I'm trying to get all the info I can up front, may do it this winter. I live in Lesslie next to Shandon (housing developement next to the reservation). Where are you? There is at least 1 other member here that lives in Rock Hill near Kmart.....69novass, I'm supposed to visit him Tues or Wed sometime. He is building a 4wd, 72 I think. Can you meet also? I'm currently on nightshift. By the way, what's your REAL name? Greg
p.s. Add the city to your profile (I think) and it will be there when you're selling or buying and people don't have to ask.
09-06-2005, 09:35 AM | #8 |
sorry my name is Scott and i live off 901. i know greg 69novass .let me know what day you guys meet and i will try to come...
Thanks Scott |
09-06-2005, 10:34 PM | #9 |
Senoir Member
I'm going to TRY to get by Greg's house tomorrw (Wed) around 2:30 on my way to a side job before I go to work nightshift. I said try, because it has alot to do with what time I can get up. If I don't make it or you can't, we can always look at other days. I'm working nights thru Sunday night. Greg
