Old 09-01-2005, 03:53 PM   #1
SkyBlue72'
crossmember question
I have a 1960 chevy stepside that will be my next project and I'm wondering. Did they all come w/ the torsion bar setup up front or did some come with the standard coil spring set up?
Also, would a 1973-84 frontend fit underneath the frontend or do I need to do some fabbing?
SkyBlue72' is offline   Reply With Quote
Old 09-01-2005, 05:33 PM   #2
chevy283
chevy283's Avatar
they all came with torsion bar i've heard that the 73-89 subs to 91 and will fit. any pics?
65 c10 tore apart
70 c10 305/350th
chevy283 is offline   Reply With Quote
Old 09-12-2005, 07:08 PM   #3
jim walker
jim walker's Avatar
1960 to 1962 came with torsion bar front suspension, 1963 saw the change to coil fronts.
jim walker is offline   Reply With Quote
Old 09-12-2005, 07:35 PM   #4
a squarecan
I have never had to do this, but too my knowledge the 60-62 frame is a little narrower then the 63-87(91 burb) frame. So I have heard of people narrowing the cross member or just shimming the crossmember.
Keith
a squarecan is offline   Reply With Quote
Old 09-12-2005, 09:24 PM   #5
zenish
theres a couple of people at www.chevytalk.com that have made this swap.
1964 c10 short step
1962 econoline van
1989 rs camaro
2006 yamaha vino 125
1975 goldwing
zenish is offline   Reply With Quote
Old 09-30-2005, 12:01 AM   #6
SkyBlue72'
I measured the framerails finally today, and found that they were exactly the same and I'm sure an 85 xmember would fit w/ some mods to two holes.
I'm also hearing that the later setup are atleast an inch wider on each side(from spindle to spindle) But I'll see if that's true or not. I see if I can post pics later on.
Old 09-30-2005, 01:18 AM   #7
62ChevyStep
62ChevyStep's Avatar
I have a 62' Step, with a mid 80's chevy P/U crossmember brake rotor to brake rotor swapped in. with the power brakes, power steering it's a dream to drive.
This picture is with it photoshopped to get an idea how it will sit on the BC Smoothie II's I ordered.
________________________
62' 3.5/5 drop SWB Fleet, PS, PB-Dsk/Drm,350/700R4
08' Chevrolet Silverado CrewCab
05'Toyota Tacoma Prerunner SR5
62ChevyStep is offline   Reply With Quote
Old 09-30-2005, 10:22 AM   #8
bpmcgee
bpmcgee's Avatar
I think the 4wd trucks did NOT come with torsion bar front end. Not sure if this helps or not
Brian
bpmcgee is offline   Reply With Quote
