09-01-2005, 06:33 PM | #1 |
Frame dimensions?
Where can I find frame dimensions to check squareness? I have the assembly manual and it is not in there, and I looked in the chassis manual and did not see it in there. I think my frame is slightly out and I want to fix it before I bolt to much stuff back on it.
Mike
Mike Redpath |
09-01-2005, 06:53 PM | #2 |
You don't need the dimensions to check for a bent frame. Any decent shop with frame alignment equipment can verify the frame symmetry. I did this with mine prior to reassembly. I got a slick color report with all of the dimensions and variances and peace of mind for about $100. The variances were miniscule, but I still actually used the information while shimming my body mounts.
71 Blazer / GMPP ZZ383 / MPFI / 700R4 / 4-Wheel Disk / Ground-up frame off almost completed resto-mod Last edited by 71RestoRod; 09-01-2005 at 06:54 PM. |
09-01-2005, 08:28 PM | #3 |
09-02-2005, 08:57 AM | #4 | |
The LuvShack Garage
LINK KURT
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
09-02-2005, 12:42 PM | #5 |
Thanks for the info, but the numbers I am after is the "X" dimensions between the two rails. I think the right rail sits slightly back from the right. The info on that web page don't give those numbers.
Mike
Mike Redpath |
09-03-2005, 10:46 AM | #6 |
Why dont you just go out and measure it? if both the measurments are the same, then your from isnt twisted. just do it from opp corner to opp corner.
-Cameron
1972 Dark blue, Cst, Highlander |
09-03-2005, 11:33 AM | #7 |
I have measured it. I keep getting conflictling measurements depending on which holes I use. If I knew which ones were the alignment holes I could get some accurate measurements. I have come to the conculsion many of the holes are hand drilled in the general areas. The alignment holeswould be the same for all frames.
Mike
Mike Redpath |
