Old 09-01-2005, 07:30 PM   #1
uk72step
outta the car velocityboy
uk72step's Avatar
Bed Off (almost I Think)
Hey there,
Righto finally bit the bullet. Threw the truck in the garage & got stuck in. Have disconnected the wiring loom, taken out the 8 bed to frame bolts which go thru the timber (the big suckers with offset washers). The bed should just lift off now right????
Or have I missed something?
Cheers
Lee
..give it a turn here, take some wedge out there, we'll win some races...
uk72step is offline   Reply With Quote
Old 09-01-2005, 07:55 PM   #2
Green Machine
Green Machine's Avatar
May or may not be a ground strap between the frame and box, might want to remove tailgate now to make it lighter if you haven't already, check for interference with rear bumper, and remove first if needed, but then you should be good to go.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 09-01-2005, 08:28 PM   #3
71swb4x4
71swb4x4's Avatar
I pulled my rear tires off and lowered the back end as low as I could get it. It made pulliing the bed off and putting it back on a breeze.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 09-01-2005, 08:56 PM   #4
raidermanny
raidermanny's Avatar
Hope you have some help, that sucker is gonna be heavy.
raidermanny is offline   Reply With Quote
Old 09-01-2005, 09:40 PM   #5
71swb4x4
71swb4x4's Avatar
It shouldn't be too bad. We did my short fleet with three people, I can't imagine the step would be much heavier. I would recommend four people just to make it easy.
