09-02-2005, 04:15 PM | #1 |
Its a Truck Thing......
Replacement Fuel Float
Anyone found a good replacement for the fuel float, the new ones I ve received only last about 2 weeks before they leak (Taiwan or china made floats suck "My Opinion") , I tried to seal them with JB weld and now there too heavy, anyone looked into a plastic one or a suitable replacement?????
Maybe its time to dig out some new tanks and see whats in them... Thanks Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 69 C30 Former Motor Home, Flat Bed time 70 G20 Red-E-Kamp Conversion "I'm your Boogy Van" Last edited by 71meangreenc10; 09-02-2005 at 04:16 PM. |
09-03-2005, 05:17 PM | #2 |
Flamin' Bass
Meangreen,
No, but I'm still lookin'. I'm on my third one in three years. 2 weeks ago, I knew I had a full tank but the float was sitting on the bottom, full of gas. I had already re-soldered and topped that one off with JB, just around the center seam. Lasted almost a year. Posted on the board and got the suggestion to coat the float completely with JB. I did that, kept it real thin, but she still seemed awful heavy. Sure enough, I put everything back together this morning, filled er up and, @&%$*#, gauge is showing less than a quarter, so I guess it's floating somewhere near the bottom. I'm looking for a cork or solid plastic float. The Cavileer (and I'm sure others) has a solid plastic one. I'm NOT looking forward to using up that d$mn expensive gas and dropping the tank, AGAIN!! BTW: Anyone know how a 21(?) gallon (poly Blazer)tank can take 21.45 gallons of fuel? That's what it showed on the pump, and I had about a gallon in there already...... Good luck,
Rick Olson /nosto/ Galloway, NJ Pics : http://community.webshots.com/user/nosto53 1972 Triumph TR6 - full resto, now with a Toyota 5-speed 1975 F**D F-100 - rusty, but reliable 1982 HD XLH-1000 1967 C-10, shortstep, 350/M21 4spd, nitrogen tank fills fast bags on 4 corners, Toyo 255/45X20s on American Eagle 221 20X8s, shaved locks and handles, antenna, fuel filler, tiny C-notch, rear fuel tank, long headers, Edelbrock, worn 600 Holley, Checkmate flush hard cover, rear pan, custom LED taillights - painted it, too! But don't like it so I'm gonna do it again!! |
09-03-2005, 06:06 PM | #3 |
if the floats are dipped in gastank sealer they'll float good for a long time
09-03-2005, 06:40 PM | #4 |
Kragen
Martin Gibson
USAF Retired 1964(-ish) C10 |
09-03-2005, 07:45 PM | #5 |
the float i got that came with the sender unit from Chevy duty still works after a week....
-Steve |
09-03-2005, 09:47 PM | #6 |
I've used MasterSeries Permanent Rust Sealer to prime my chassis and the instructions say it can be used to seal fuel cells and should work if painted on the float. POR15 is a moisture curing urethane also, so why not give it a shot?
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. |
09-03-2005, 10:21 PM | #7 |
blood type; Retumbo
they are dimensionally the same as what is available from ford. I will have to check my toolbox at work on Monday for the part #. (I have a spare just in case)
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
09-04-2005, 07:05 PM | #8 |
Good news,
Hopefully you will find that number for me, I have had some good ones in the past, but soon as the truck sets the float goes bad, Im tired of trying products on the floats, I dont mind pulling the one out of the 68 behind the seat, but I m not going to keep droppin the tank under the bed of the 71....youd think one of the aftermarket guys would make a replacement plastic float,,,,would make a killing in my opinion........ Smitty..... I am going to check out a corsica float this week....
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 69 C30 Former Motor Home, Flat Bed time 70 G20 Red-E-Kamp Conversion "I'm your Boogy Van" |
09-04-2005, 09:10 PM | #9 |
blood type; Retumbo
the Ford one IS plastic.
09-04-2005, 10:43 PM | #10 |
What years and models please........
09-04-2005, 11:44 PM | #11 |
We had to replace the sending unit float in my great Uncle's 1981? Ford F100 and the new float looked just like the ones for our trucks. Costed about 6 or 7 bucks at the Ford dealer, they had about 12 in stock too.
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck |
09-06-2005, 12:04 AM | #12 |
Good info,
Thanks Smitty
