Old 09-02-2005, 10:05 PM   #1
motocrosschump
V Belt
I am having problems with my V-belt screltching. I have replaced it three times but it only helps for a few days. So today I bought a Gibbs belt, which is suppose to better. It started Screltching (don't even know if that is a word) as soon as I put it on.
Why is it doing this?
2006 Titan SE Crew Cab Daily Driver
2005 Mazda Tribute (Wifes car)
1969 C10 SWB 350/3 Fleet "Max"
1969 Chevelle 2 door 350/3
motocrosschump is offline   Reply With Quote
Old 09-02-2005, 10:10 PM   #2
hilljob26
hilljob26's Avatar
take some kind of a solid form of polish or buffing compund,and touch it to the belt(where the v is on each side) as it is running,and also make sure that the belt is aqs tight as you can get it
21 2500hd duramax
58 apache
HILLJOB GRAPHIX--for all your graphic needs
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=542497
LS ENGINE SWAP INFORMATION THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=377348
4l60 to an NP205
http://67-72chevytrucks.com/vboard/s...43#post3697343
hilljob26 is offline   Reply With Quote
Old 09-02-2005, 10:18 PM   #3
motocrosschump
Thanks..btw is Gates not gibbs
Old 09-03-2005, 12:25 AM   #4
jhow66
jhow66's Avatar
Your alt. or water pump bearing may be trying to lock up.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 09-03-2005, 08:05 AM   #5
Blazer1970
Blazer1970's Avatar
The pulleys are probably worn out.
Blazer1970 is offline   Reply With Quote
