09-03-2005, 02:31 AM | #1 |
3/4T 4x4 spring lift and rearend change
Hi guys. Im planning to drop a 1977 14bFF under the rear of my 69 K20. At the same time, I am going to get 2 inch aprings made for all around the truck. What kind of geometry issues will I run into. Someone needs to write a rearend change FAQ. Thank you all
69 chevy 1/2 ton 2wd 72 GMC 1/2 ton 2wd |
09-03-2005, 09:02 AM | #2 |
Post Whore
The spring perches will need to be moved and you will need a conversion u-joint for your driveshaft. I don't know if the driveshaft length will actually change. My info on the u-joint conversion is at the office but someone will probably chime in on what it is.
You could PM Beast388 he has the specific info.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
09-04-2005, 11:26 PM | #3 | |
72 C20 4X4 454 4 speed 89 Trans Am (was) 305 TPI 700r4 93 C1500 2wd Extended cab 350 700r4 98 Sonoma (TPI outa the Trans Am) 03 Yamaha 660 Raptor 03/04 660 Raptor 07 700 Raptor 85 Honda Odyssey |
09-05-2005, 01:09 AM | #4 |
what is the factory angle that the front and rear differentials are set at? If I use 2 inch lift springs, maybe someone better at geometry could figure out what the new angle would be.
09-05-2005, 02:01 AM | #5 |
the 3/4 ton ujoint is proly gonna be a 1350, and the 14bolt axle is prolly a 1ton/1410 series, in which a conversion ujoint(like neapco, PDQ, fed mogul) of 3-3130(or maybe 3-3150) which one set is 1350 caps and the other pair of caps is 1410 caps)
09-06-2005, 09:00 PM | #6 |
Suburbans RULE!
The 14BFF uses a 1350 u-joint. Your original K20 driveshaft "should" be the 1350 as well. I had to use the Napa #348 conversion joint since my burb was a 1/2 ton.
The 14BFF in my Burb is also of the '77 variety. You will need to move the spring perches from the 42.5" spacing to the 40" spacing your '69 K20 requires. You will also need to move the shock tabs to the "both forward" configuration at the correct spacing. Let me know if you want to see some pics and I will post them.
--Ben 71 GMC Suburban 4X4 The "Beast" 388 CID Stroker, TH350, NP205, 8-lug D44, 14BFF w/ Detroit, 4.10:1 gears, 4-Wheel Disks 4" Lift, 35" MT/R's. |
