Finally a Bulldawg
differences between 1/2ton and 3/4ton
I have a 72 C10 and I was wondering what differences there are between my truck and a 3/4ton. I want to beef up the suspension and hopefully get the truck to sit level rather than hunched down in the front and I thought maybe a few 3/4ton parts would do the trick.
Thats the Hillbilly way
Heavier front spring would help lift the front end .
Bill ![]()
BILL Torrance Calif 90504 Member DUF Club Member Old Farts Club 72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion. " If I knew I was going to live this long I would have taken better care of myself " Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER.... Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen , |
Finally a Bulldawg
whereabouts can I find a heavier fron spring? Who sells them?
registered IWATA user
Early Classic Enterprises, www.earlyclassic.com, there are also a couple of people on the board that sell parts
-'63 Ford Fairlane 500 coupe, v8, auto, faded and rusty. awaiting built roller 302 and some flat black -'99 Honda Prelude. vtech/5spd. no pipe, no intake, bone stock. awaiting new top end. -01 GMC Yukon SLT 5.3 dented and scratched with a noisy tranny. Take off that Von Dutch hat before i stab you with a 000 Mack. |
![]() Join Date: Jun 2000
If all you want is a raise, longer springs are the way to go. The heavier springs aren't always longer, just heavier (ugh). You can get custom spings made for reasonable prices to your own specs--length & weight rating. Check these guys out first:
http://www.eatonsprings.com/ To beef it up other than just springs, you'll need new spindles, brakes (incl. master cyl), ball joints, etc. Which will also give you 8 lugs. Could get pretty involved... Good luck! ![]()
Ben '68 Chevy C10 Custom LWB 327/TH400 2nd owner '16 GMC Sierra 1500 SLE Dblcab 4wd 5.3 Last edited by ThreeQuarter; 07-12-2002 at 03:50 PM. |
Led Sled! Discs R 4 ME!
![]() Join Date: Jan 2001
You can also lower the rear to level the rake out.
Rasing the front w/o suspension mods will alter the front suspension geometry |
