Old 09-04-2005, 05:36 PM   #1
bisquik65
bisquik65's Avatar
462 double hump heads f/s $300 shipped u.s.
I have here a set of 66 327 heads,1.94 intake 1.50 exhaust and have had a recent valve job on them,they will need to be surfaced very little,slight pitting on the corner in last pic,nothing deep,just enough that i would say less than .010 would fix them up,mabye not even that much,i traded a good friend a running car for them,just trying to get something out of them. I nice matching pair of heads...
bisquik65 is offline   Reply With Quote
Old 09-04-2005, 09:03 PM   #2
acloco
Those would be made for 1967....300hp 327 or 300hp 350........
acloco is offline   Reply With Quote
Old 09-04-2005, 09:40 PM   #3
bisquik65
bisquik65's Avatar
TTT yes dated for a 67 model year...k-10-6
Old 09-04-2005, 10:27 PM   #4
acloco
Nothing like adding 1.0 to the compression ration.....PERFECT for those dished piston 350's!
Old 09-05-2005, 10:47 PM   #5
bisquik65
bisquik65's Avatar
Yes they will fit,you just need a aftermarkes alt bracket for the early cars,any advance auto or autozone has them on the shelf....You can both them right up...will work great..i have all big blocks but one and just dont need them..
Old 09-05-2005, 11:05 PM   #6
bisquik65
bisquik65's Avatar
A mild built 350 with a mild cam should run a 600 cfm single feed,I run all edelbrocks on mine,I would say you are getting way to much gas with that carb...Try a 600 eddy and it will make a hugh difference,they are not that much . The gas saving over time is enough to get one..This carb will double the power you have and run R44T a/c plugs... Add a hei curve kit in the dist and a 77 corvette vacume advance unit...Will gain you about 35 hp....
Old 09-06-2005, 09:43 AM   #7
Brewski*
Brewski*'s Avatar
Do they have accessory holes?
Brewski* is offline   Reply With Quote
Old 09-06-2005, 10:20 AM   #8
tnblazerk5
User #12137
tnblazerk5's Avatar
no double hump heads do not have them
tnblazerk5 is offline   Reply With Quote
Old 09-06-2005, 09:03 PM   #9
bisquik65
bisquik65's Avatar
Thanks robb yes no accesery holes in them....pre 68 car heads...
Old 09-06-2005, 09:09 PM   #10
bigjimzlll
bigjimzlll's Avatar
Most double humps do not have them...some do. casting number 186 has them
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 09-06-2005, 09:58 PM   #11
bisquik65
bisquik65's Avatar
Any takers before they go to ebay?
