Old 09-05-2005, 01:14 AM   #1
gregbr
Senoir Member
gregbr's Avatar
700r4 in a 4wd question??
Hi. This has probably been covered several times, but I could not find it. When converting a factory T350 4wd to a 700r4, I've read the output shaft of the 700r4 must be changed out to an Advanced Adaptors 27 spline shaft. If you find a 700r4 from a 4wd does the output shaft still have to be changed?? If so, what's different between the AA shaft and the 700r4 4wd output shaft? Is the swap REALLY worth all the time & money? Greg
67 Chevy, Small back glass, Factory 4WD, Factory Shortbed, Factory V8, Lifted 4"
70 GMC Sierra Grande, Factory Shortbed, Factory 402/400 turbo, Super Custom Interior. Numbers matching with SPID & Build Sheet. 68K Original Miles. Restored 2010
70 GMC Restoration Pictures
http://67-72chevytrucks.com/gallery/...00&ppuser=4424
gregbr is offline   Reply With Quote
Old 09-05-2005, 01:22 AM   #2
Ed ke6bnl
no expert but the 700r4 froma a 4x will fit in place of you t350 the catch is you need an adaptor for spacing out the 700 off the transfere case I know because my boy has one he had made. I believe the 700r4 needs the shorter shaft output. and the 700 is not a very strong transmission and the drive shaft may need altering. lets hear it from the expert they are out there Ed ke6bnl
Ed ke6bnl
Agua Dulce
70 S.E. Los Angeles
70 Chevy short bed
1948 F3 ford pu
1949 F1 stock V8 flathead 3 on floor
1950 F1 pu street rod
1948 F6 Ford Dually/350sbc no bed stock trans&rear
1972 El Camino 4" chop
1953 Chevy 3100 2b daily driver
1970 SB 4X4 400ci 6in lift
Ed ke6bnl is offline   Reply With Quote
Old 09-05-2005, 10:30 AM   #3
Rod
4wd or 2wd the output shaft on the 700r4 is still 32 spline. You need to either change the transfer case to accept the 700r4 by either
changing the output on the transfer case to a 32 spline input...
or change the output on the 700r4 to a 27 spline..
or change the coupler between the tranny and tranfser case to 27spline one side and 32 spline the other
Most of these suggestions are based on a NP205 that was coupled to 350 automatic.
There are a few different ways to do it as I listed...someone here made a nifty adapter spacer also.
Lots of stuff on the web about this swap...I'll see if I can attach some links later.
I got 3 trees and lots of branches that came down in the yard yesterday after a little nasty rain and wind storm here last night. They came down missing anything important.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 09-05-2005, 09:21 PM   #4
gregbr
Senoir Member
gregbr's Avatar
Thanks Rod, I never saw anywhere how many splines are on the 700r4. Makes sense now. Greg
