Old 09-05-2005, 09:49 AM   #1
57sailplane
57sailplane's Avatar
6" drop
i was wondering if any of you have pictures of a truck with a 6" drop in the front that still retains the spring suspension. i want to see how she will look. thnks andrew
57sailplane is offline   Reply With Quote
Old 09-05-2005, 11:32 AM   #2
SCOTI
SCOTI's Avatar
6" front drop w/spindles & cut stock 6cyl springs.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 09-05-2005, 06:32 PM   #3
67pro-street
67pro-street's Avatar
heres mine, its about a 5/7 with spindles and springs up front and blocks and springs out back.
67pro-street is offline   Reply With Quote
Old 09-05-2005, 07:01 PM   #4
57sailplane
those trucks look great. awsome. how are the handling characteristics. do they bottom out easily.
Old 09-05-2005, 07:03 PM   #5
67pro-street
mine doesnt really have a problem with bottoming out. usually the only thing that hits is the exhaust and headers. they are hooker competitions.
Old 09-30-2005, 07:57 PM   #6
57sailplane
anybody else?
Old 09-30-2005, 10:29 PM   #7
riden2low
I have a 4/6 and was hitting the headers on speed bumps and etc. Got tired of exhaust leaks and took them off. Now I have ram horns from a Chev Dealer that sells performance stuff and got a set of horns with a 2 1/2 exhaust opening for 99.00 a side. Got 2 1/2 all the way back and no more leaks. Had the exhaust boys tuck the exhaust up with in the frame so there is no ugly exhaust visible.
riden2low is offline   Reply With Quote
Old 09-30-2005, 10:44 PM   #8
SCOTI
SCOTI's Avatar
I took off headers & put on a stock manifold on my 6cyl & then had the exhaust tucked up close to the bottom of the floorpans.
No bottoming out issues. The tires do buzz the tops of the fenderwells up front if I hit a big dip in the road @ high speed. At the ride height in the pic, I have towed my 74 swb truck on my 18ft steel floor car hauler w/o issue (other than the 6cyl/3spd struggling to pull the weight uphill).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-30-2005, 11:55 PM   #9
powell72
powell72's Avatar
Are you guys able to get your trucks aligned being that low? I'm assuming you are using the stock upper control arms. The only reason I ask is when i took mine to get aligned the guy said if it was any lower he wouldn't have been able to get the settings within spec.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 10-01-2005, 02:49 AM   #10
smbrouss70
smbrouss70's Avatar
How tall are you guy's front tires? I'm running a 26" tall tire with a 4.5" drop up front (2.5" spindles & 2" coils) and I have to be careful on the roads around here to keep from dragging my LCA's on the ground. They hit before my bump stop comes into contact with the crossmember.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 10-01-2005, 11:57 AM   #11
Robznob11
Robznob11's Avatar
i don't know how your trucks look so low with such little drop. mine has 3 in springs 2.5 spindles and out back it has 6" springs with a 3" body drop all around. here is what it looks like.of coarse it will set down in the front with the motor and body but i would think it would not be mutch lower than the rest posted here???
Robznob11 is offline   Reply With Quote
Old 10-01-2005, 12:54 PM   #12
smbrouss70
smbrouss70's Avatar
This is what my truck really looks like, in case you were referring to my "enhanced" version for my avatar.
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 10-01-2005, 05:47 PM   #13
72MARIO
72MARIO's Avatar
I have a 3.5 front drop and the guy at GM said I would have camber/caster issues if it was any lower.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 10-01-2005, 11:17 PM   #14
SCOTI
SCOTI's Avatar
If he knew what to do, you wouldn't have problems. Both of my 'drivers' are @ least 5" front drops & aligned w/o any drama. The key factor is using drop spindles or changing the location of the a-arm mounting points vs. the main frame rails (z-ing the frame, notching the c-member, etc...).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
