Old 09-05-2005, 09:17 PM   #1
SCOTI
SCOTI's Avatar
Gas Gauge Stopped Working
Anyone had this dilemma?
My gas gauge has always read slightly off. When filled it would read 1/4 tank past the full mark & then once it hit the 1/2 tank mark it went to empty pretty quickly. No big deal.
About 3~4 weeks ago it started something new. Now, it will sit around the full mark & when you hit the ignition, it swings over to the 3 o'clock position & stays there (full or empty). It sucks having to put gas in every 3-days because you don't know how much is in it.
I looked @ the tan wire that runs to the solenoid (pwr to sending unit?) & it appears to be of sound quality & the ground looks good @ the frame (near the tank, inside the framerail).
What else could it be? I checked fuses & nothing apparent there.
Any suggestions?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-06-2005, 12:25 AM   #2
chevykid77
chevykid77's Avatar
it could also be the connections on the back of the guage its self i have had that happen its not getting connection sometimes if you hit dash it will come back but more than likely you will have to remove cluster and clean connections on back of guage....
chevykid77 is offline   Reply With Quote
Old 09-06-2005, 12:25 AM   #3
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
That's a grounding problem. Check the ground to make sure the wire to the sending unit is okay along with the post it grounds to. Does it do it to both tanks or just one?
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 09-06-2005, 12:27 AM   #4
SCOTI
SCOTI's Avatar
Single tank.
Ground felt fine @ the frame. You can't really get to it on top of the tank though w/o dropping it.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-06-2005, 12:31 AM   #5
79BIG10
79BIG10's Avatar
Might also be the wire itself broken or a short in it. I don't think that it could be a ground at the gauge but never know.
Old 09-06-2005, 10:35 AM   #6
SCOTI
SCOTI's Avatar
My next step is run a temp power wire w/some clips & see if it makes a difference.
Thanks for the suggestions.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-06-2005, 06:44 PM   #7
SSC's76
No No
SSC's76's Avatar
Ground issue, might be broken in the sender itself. My truck was doing this all summer then the day I was going to fix it it started working again. Gotta love when they fix themselfs.
See if you can drop the tank low enough to get the plug off then play with the ground on the sender and see what the guage does.
1976 Custom Deluxe SWB Med FMB.3/4 Drop.
Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out.
1997 K1500 ext cab 5.7 stock except muffler
SSC's76 is offline   Reply With Quote
Old 09-17-2005, 06:05 AM   #8
DrMaserati
Village Curmudgeon
Don't waste your time running another power wire. As stated above, what you are describing is caused by poor/lack of ground. If you had no power to the sender it would not come off of empty. With power to the sender but a bad ground it will peg past full.
JP
78 Chevy K30 duallie, 454, TH400
78 IH Scout II, 4X4, 345, 727TF
76 IH Scout II, 4X4, 345, 727TF
65 IH 1200C pickup, 4X4, 345, 4 spd
48 IH KB-8-F, RD-450, 5 spd, 35,000 GVW (a REAL truck)
"Life is too short to drink cheap beer." Harry S. Truman
DrMaserati is offline   Reply With Quote
Old 09-17-2005, 01:11 PM   #9
SCOTI
SCOTI's Avatar
JP
I should have been more specific.
If I'm there to run one wire for testing, I'll do both. I'll run a hot lead & see if there's a difference & a new ground & see if there's a difference.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-19-2005, 09:51 AM   #10
SWR
Were you able to figure out the cause of your gauge problem? Mine does the exact same thing. I just haven't had time to look into it yet.
Thanks.
SWR is offline   Reply With Quote
