Old 09-05-2005, 11:07 PM   #1
imbio
Need help on mounting a front sway bar on 72 K10.
I am new to the forum and need help on mounting a sway bar on my 72 K10. I have the spring mounts, but did not see which way they were originally mounted, or how the bar was attached to the frame. Does the bar mount to the spring mounts on the left or right? One side of the bar has an offset. Does the offset go on the driver side? One big question is when the bar is laying on the ground, the ends do not appear to be on the same plane. One end sits slightly off the ground while the other end sits on the ground. Is this wrong or is the offset compensated when mountin to the frame? Are the frame mounting brackets unique, or are they easily fabricated?
Any and all help appreciated. Pics would help also!
Thanks again,
Steve
imbio is offline   Reply With Quote
Old 09-05-2005, 11:31 PM   #2
earl87gta
earl87gta's Avatar
I dont think the 72 ever came with one you will have to make a cross member to hook it on to I have one on my 72 blazer from a 80s k5 Ill try to snap a few pics of it tomarrow for you so you can see how I have it on the blazer.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 09-06-2005, 01:07 AM   #3
4x4Poet
I have a few threads saved:
http://67-72chevytrucks.com/vboard/s....php3?t=130117 (another thread linked, too)
http://67-72chevytrucks.com/vboard/s....php3?t=139884 (Good pics of Bobbyk fab work)
http://67-72chevytrucks.com/vboard/s....php3?t=140662 (More of a 2wd focus)
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 09-06-2005, 07:32 AM   #4
imbio
Thanks Earl!
Steve
Old 09-06-2005, 07:35 AM   #5
imbio
Before I forget, is mine tweaked, since both ends won't touch the ground at the same time?
Thanks again for the help!
Steve
Old 09-06-2005, 07:14 PM   #6
cheyenne10
cheyenne10's Avatar
Anyone fabbing brackets yet?
Who is interested in fabbing the brackets like BobbyK to sell? I am ready to buy a set.
Bob
cheyenne10 is offline   Reply With Quote
Old 09-06-2005, 09:32 PM   #7
earl87gta
earl87gta's Avatar
Hope the pics help you out I used a pice of 2x4 steel to make it but I plan on redewing it with the same tubing as my roll bars and the sliders Im making so that it looks a little better.
Earl
Old 09-06-2005, 09:37 PM   #8
earl87gta
earl87gta's Avatar
let me know if you need more
Earl
Old 09-06-2005, 11:13 PM   #9
imbio
Thank You!!! This was exactly what I was looking for.
Steve
Old 09-07-2005, 12:40 AM   #10
earl87gta
earl87gta's Avatar
Glad to help not as High tech as bobbyK but it works.
Earl
Old 09-07-2005, 01:18 AM   #11
earl87gta
earl87gta's Avatar
first pics
Earl
Old 09-07-2005, 01:23 AM   #12
earl87gta
earl87gta's Avatar
next
Earl
