Old 09-06-2005, 01:39 AM   #1
bearmtnmartin
backseat legroom fix
Hi folks,
I am starting on my second blazer. I parted my first one out due to unrepairable rust. One thing that always bugged me a bit was the lack of legroom in the back. I am thinking of putting the next tub on a newer frame, with the drop in it for a proper back seat. Anyone ever try this?
Martin
bearmtnmartin is offline   Reply With Quote
Old 09-06-2005, 07:47 AM   #2
Blazer1970
Blazer1970's Avatar
I don't think they really changed the frame between '77 and '78 when they changed the tub and rear seat. All they did was moved two of the cab mounts from inside the frame rails to outside.
Blazer1970 is offline   Reply With Quote
Old 09-06-2005, 07:15 PM   #3
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Sounds like a lot of work for a minimal problem. I've seen people move the seat back toward the tailgate so passengers can stretch out their legs a little more.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 09-06-2005, 11:15 PM   #4
bearmtnmartin
thanks for your thoughts. I know it would be a pain to do. But I might try it anyway. In addition to a better backseat, you would be able to slide the front seats further back.
martin
Old 09-07-2005, 12:26 AM   #5
vtblazer
vtblazer's Avatar
Or maybe build up the seat base so it sits higher, giving you the desired result without any other mods.
vtblazer is offline   Reply With Quote
Old 09-07-2005, 03:01 PM   #6
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
AND
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Big Piggy: "Goliath" 07 Kodiak C4500
Lil Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 09-07-2005, 04:25 PM   #7
meathead95
computer illiterate
meathead95's Avatar
i plan on doing the same thing to my 2wd blazer
72 2wd blazer
72 swb 4x4
meathead95 is offline   Reply With Quote
Old 09-07-2005, 11:13 PM   #8
71swb4x4
71swb4x4's Avatar
I have thought about building the seat up on my Jimmy. That would give me more leg room for anyone back there, and I could raise that portion of the floor to allow for a bigger notch.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 09-08-2005, 07:04 AM   #9
Blazer1970
Blazer1970's Avatar
IMO the rear seat already sits up way too high.
Old 09-09-2005, 01:57 AM   #10
71jimmy
71jimmy's Avatar
I only let short people ride back there, tall folks walk. End of problem.
'71 Jimmy, 350, SM465, NP205, 2in Tuff Country lift, 33s on rallies, TBI, softtop and hardtop
"If life was fair you'd be able to afford one of each and a garage large enough to house them all."
71jimmy is offline   Reply With Quote
Old 09-10-2005, 01:11 PM   #11
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I have no problems sitting in the back but then agian I am only 5'-9''
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
