VIN Location
I have owned my 1972 K20 Truck for 5 years and just now the inspection place called me to say that they can't check the truck until they can verify the Vin matches the registration. Where can i find the VIN? I no longer have a sticker on the glove box door. Thanks.
Brad
1972 K-20 lwb fleetside, 355ci 425hp at flywheel, good for 17.7 1/4 mile with 33's and SM465. 1982 Yamaha Virago -York Haven, PA (south central PA) |
There should be a metal plate riveted in the driver's door jamb that has the VIN on it.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
its all about the +6 inches
And a partial VIN stamped on teh frame. The drivers side forward frame rail, juts to the rear of the steering gear box on top. The same thing is also under the cab, but you can't see it onless the cab is missing.
