Old 09-06-2005, 10:13 AM   #1
71400lb
71400lb
Cold Cranking Amps..what are they?
Okay, question...
I have a 71 3/4 Ton Cheyenne with a 400 SBC and a 400 Turbo auto/2wd.
My battery is a 1000 cold cranking amps and 850 cranking amps A/C Delco battery...the little green light is almost completely out, but you can still see a sligth glow.
I have a buddy who can give me for free a 690 cold cranking amps/550 cranking amps new Interstate battery.
Can I use the 690 CCA/550CA in place of my 1000 CCA/850 CA battery, or will I have problems?
Thanks,
71400LB
1971 Cheyenne 3/4 Ton/2wd
400 SBC 4 bbl Quadrajet/400 Turbo/3.73/Open
Dual Flowmaster Exhausts
71400lb is offline   Reply With Quote
Old 09-06-2005, 06:29 PM   #2
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
The definition of the Cold-Cranking Amperage (CCA) of an automotive battery is the amount of current a given battery can deliver for 30 seconds at zero (0) degrees F without dropping below a specified cutoff voltage (manufacturer-specific, but usually 10.5 volts).
sneakysnake is offline   Reply With Quote
Old 09-06-2005, 06:36 PM   #3
sneakysnake
This says for a 400ci requires 400 cca.
http://www.bgsoflex.com/cca.html
Old 09-07-2005, 01:56 AM   #4
purple gas
400 cold cranking amps!! Ah to live in your southern climes. In a few weeks from now. Well hopefully a few months, when it's -40 in my part of the planet ( farrenheit or celciius at that temp it's all the same ) Where your tires have flat spots for 3 blocks & your seet feels like a frozen chunk of cement 400 Cold amps would hardly make the interior light glow let alone turn a motor filled with oil as stiff as peanut butter.. But then again, we don't get any hurricanes,Volcanoes, Earth Quakes or shark attacks.
I got a bench seat baby, you don't have to sit over there.
purple gas is offline   Reply With Quote
Old 09-07-2005, 02:03 AM   #5
Russell
Professional Grade
Russell's Avatar
Yep, I run a 1200 cold cranking amp battery in my GMC. While all the weeners at school are trying to get their 2005 civics to crank over, I hit the key and the truck fires right up. Usually knocks for a few seconds until the oil pump is able to get that peanut butter oil flowin, lol.
You ever get so cold there that your rear end fluid turns into jelly? One morning it was -50 C here, and my truck was lugging real hard to get it moving, found out later that the oil in the rear end was freezing, making a bunch of drag on the truck. The thing that truely amazes me -- School was still in at those temps, lol! Yep, hard as heck on an engine to start it in the cold, but the GMC never once let me down, and usually within 5 minutes, had at least some semblance of heat coming from the vents :P Most of the time during those temps, the temp needle never comes off the C, even if you drive for 30 minutes, the air sucks the heat out of the engine / rad faster than the engine can produce it!
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 09-08-2005, 11:31 AM   #6
Gordo
Another interesting site about batteries
http://www.uuhome.de/william.darden/
1971 C10 swb stepside 350/700R4/3.73posi (retired as of 4/22/03)
1998 S10 short bed
2002 S10 Blazer
1942 Oldsmobile
1958 Massey Harris Pony
1951 Wife
Killingworth, Connecticut
May those who love us, love us, any of those who do not love us, may God turn their hearts.
And if God is unable to turn their hearts, may he turn their ankles so we may know them by their limping.
A man who works with his hands is a laborer; a man who works with his hands and his brain is a craftsman; but a man who works with his hands and his brain and his heart is an artist.
Gordo is offline   Reply With Quote
Old 09-08-2005, 11:54 AM   #7
Dick Dale
Excelsior, You Fathead.
Dick Dale's Avatar
I always use 1000 CCA in beautiful Chicago winter mornings. Its not the cold, its the windchill.
Go Navy. The Sea Is Ours.
Budget 350 Build
http://67-72chevytrucks.com/vboard/s...38#post2264638
Dick Dale is offline   Reply With Quote
Old 09-08-2005, 11:59 AM   #8
raggedjim
raggedjim's Avatar
Charge your battery and have the alternator checked out. If the altenator is good the battery should maintain the charge.
Good luck, Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743
raggedjim is offline   Reply With Quote
Old 09-08-2005, 12:02 PM   #9
raggedjim
raggedjim's Avatar
Oh, I forgot to add, you can use the other battery if you want. It will start your truck in most situations, but if the temp gets stupid (0 or below) it may give up on you.
Rg
Roger
'70 GMC Jimmy 2wd
Old 09-08-2005, 04:33 PM   #10
Maximum Overdrive
December 21, 2012
In cold climates rule of thumb is to run twice as many CCA as cubic inches of your motor. 350 cubic inches-----> min. 700 cold cranking amp battery.
"!Ama Sua, Ama Kjella, Ama Lllulla!"
Maximum Overdrive is offline   Reply With Quote
Old 09-08-2005, 09:58 PM   #11
al's71gmc
4 eyed fever
al's71gmc's Avatar
you have your numbers backwards. the cca is always lower than the ca, because batts deliver less juice in the cold.
when i got my truck last fall, it had a 650 ca/550 cca batt in it. it worked fine all winter with temps as low as -30 f,( i was amazed!). but i replaced it this summer anyway. if you're in cold clim, i'd run at least a 700-800 cca. I'm running a 350 ci, and put in a 990 cca batt.
1971 GMC 2500 4x4
1972 GMC Sierra Grande 1/2 t 4x4-#1 son's truck. Recently completed resto.
4 YO daughter," Daddy, I like your truck better than Mom's." (2000 F350-ranch truck) Smart kid!!
al's71gmc is offline   Reply With Quote
Old 09-08-2005, 10:19 PM   #12
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Good Lord, -50 C? I guess that would turn one's rear end fluid to - oh, you're referring to the truck's differential... sorry.....
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
