Old 09-06-2005, 06:11 PM   #1
gmcbigbl
gmcbigbl's Avatar
400 motor AKA 402 BB
The GMC build sheet reads "400 cu. in. V-8 engine"
Truck has a turbo hydra-matic tranny.
Is this a 400 sb or 402 bb
gmcbigbl is offline   Reply With Quote
Old 09-06-2005, 06:16 PM   #2
panhandler62
Java Mechanic
panhandler62's Avatar
If you post a pic twenty people will rush to answer you. lol
The fast way to tell is to look at the exhaust. Small blocks have the center ports siameezed together where the big block exhaust ports are evenly spaced.
Keith
11 Lincoln MKT -- Momma's wagon
13 G37xS -- middle age crazy car
68 C20 Fleetside -- RIP
Decorating the whole town up at a cost of $27 ....
panhandler62 is offline   Reply With Quote
Old 09-06-2005, 10:39 PM   #3
Blazer1970
Blazer1970's Avatar
If you are talking about a '67 - '72 truck it is a 402 big block. The 400 small block was never used in these trucks.
Blazer1970 is offline   Reply With Quote
Old 09-06-2005, 11:24 PM   #4
Correctamundo!!Does it have a big block in it now?
Old 09-06-2005, 11:34 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Welcome to the board from Central Ohio.
I am pretty sure you are first member from China....I'll bet parts are a real pain huh?
As stated, the 400 that was listed on these trucks would be a 402 big block, the 400 was never installed factory. In many of the '70 trucks it was still listed as a 396 on the option sheet, badged as a 400, yet was actually a 402.
Old 09-07-2005, 04:02 AM   #6
gmcbigbl
gmcbigbl's Avatar
It is a 1970 GMC Sierra Grande with the original engine. The entire truck is original with only 68000. It has the CST interior with bucket seats and console The color is yellow(ocre)? I'm gonna e-bay it soon and wanted to make sure of engine cubes.
If someone tells me how, I will post a few pics.
BTW It's not really China, just joshing
Old 09-07-2005, 07:37 AM   #7
I wundered if it was a town in Kansas or something.
Old 09-07-2005, 12:27 PM   #8
69Goody
69Goody's Avatar
My 69 GMC camper unit has a Small Block 400 in it...but it had a 350 originally and says so on the build sheet.
The 400 small blocks did not start production until 1970. As far as whether they were used in production or not...I'm not sure. I would not put it past as an option or custom request.
I believe my 400 small block came as an upgrade early in its life. Possibly to get a little more power under warranty without any other mods needed.
One way to tell would be to look at the exhaust ports on the heads. If they are evenly spaced, then you are looking at a big block motor. 0_0_0_0
If the two center exhuast ports are right next to each other 0_00_0 then you have a small block.
The sure fire way to tell is look for the block ID code imprinted on it.
I would tend to believe that if it were a big block 402, it would have said 402 on the build sheet and not 400. No one would under state the Cubic Inches.
Only the Mediocre are always at their best...
'69 GMC LWB 406, TH400, 3.73 Posi'
Things I've learned from my truck...If I was an automaker, my vehicles would be overpriced, run rough, and get 5MPG.
69Goody is offline   Reply With Quote
Old 09-07-2005, 12:43 PM   #9
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
4 bolts for each valve cover = small block
7 bolts for each valve cover = big block
Old 09-07-2005, 12:53 PM   #10
panhandler62
Java Mechanic
It's funny but, other than the simple tricks of counting bolts and looking at the exhaust ports that 69Goody, TX Firefighter and I put forth, I am having a hard time thinking of how to tell someone how to spot a rat, even though I know for a fact that I would know instantly if I was looking at one when the hood came up!
It's no wonder we have so many unsolved crimes -- people are lousey witneses! LOL
Keith
Old 09-07-2005, 02:42 PM   #11
COBRO
Active Member
Thumbs up
My 72 c-20 came with the 402 BB and its listed as a 400 on the glove box door and fender emblem so seems you have a BB - just more of the GM confusion. HTH::::CB
COBRO is offline   Reply With Quote
Old 09-07-2005, 02:50 PM   #12
mplex2000
mplex2000's Avatar
Hehe...simple panhandler...big blocks are...big :P
It is kind of funny that you (me) can look at one and see that it's a BB or SB, but how would you tell a newcomer to tell?
mplex2000 is offline   Reply With Quote
Old 09-07-2005, 03:04 PM   #13
edmonton72
Nothings as cool as my 72
edmonton72's Avatar
Are you guys sure that these trucks never came with the 400 sb? It says 400 cu. in v-8 engine on the potion list on my 72 and it has 350 in it now. My dad and i always argue about if it came with a 400 or a 402. Is there any other way to figure out if it came with a 402?
1972 C10 Longbox
In the middle of body off restoration
Rebuilt 355, turbo 400, 3.42 12-bolt
Rolling chassis finally done and cab mounted. Now onto sanding, bondo and more sanding.
edmonton72 is offline   Reply With Quote
Old 09-07-2005, 03:11 PM   #14
cableguy0
They absolutely did not put 400 small blocks in these trucks. my bet is someone blew up the 402 that was originally in your truck was blown up or swapped to a car and replaced with a much cheaper and easier to find 350
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 09-07-2005, 03:16 PM   #15
Blazer1970
Blazer1970's Avatar
Correct. 400 small blocks were used in full size cars in these years, but ABSOLUTELY NOT IN TRUCKS.
Old 09-07-2005, 03:23 PM   #16
GasHog396
Big blocks are going to have a water pump by-pass hose that goes from the intake to the pump, right on the front of the engine. It looks like a piece of heater hose that is L-shaped. A small block does not have this by-pass hose (at least none of the 1000s I've seen have had one.). A factory (short water pump) BB will also have a remote mounted power steering reservoir on the left fender. A SB pump has the reservoir incorporated on the pump.
'67 1/2 Ton Short Bed / 396 cid / AC w-R134a / 5 Lug Leaf spring rear axel / 5 Lug Frt Disk Brake Conversion
'97 Trans Am - Black / LT-1 / K&N FIPK Cold Air Kit / Hooker Cat-Back Exhaust / 160 Thermostat
'02 Buick Regal GS / Bone Stock
GasHog396 is offline   Reply With Quote
Old 09-07-2005, 05:33 PM   #17
Longhorn Man
no 400 small blcoks onless it says C.O.P.O. on the option sheet, then it MIGHT have a 400 small block. There was never a 400 small block option.
Like I said, in 70, the option sheet said 396, the fender said 400 and the engine was a 402. They DID low ball the C.I.D. ...for insurance reasons is the common stated reason.
