Old 09-06-2005, 06:38 PM   #1
cwilkie
Chance
cwilkie's Avatar
pistons play??
How much play should a piston have after it has been broken in? I am able to move my pistons in my 396 big block (casting #3855961). The reason being I pulled the engine to swap heads from open chamber to closed chamber and I noticed the pistons were black so I tried moving a few and I there is some play in between the piston and cylinder. Please let me know.
Chance
1968 Chevrolet Stepside
BB 396 w/TH400
1972 Chevrolet 3/4 Ton 4x4
BB 496 w/TH400
cwilkie is offline   Reply With Quote
Old 09-06-2005, 06:54 PM   #2
jhow66
jhow66's Avatar
Normal-as much .004 if forged pistons- less with cast.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 09-06-2005, 06:59 PM   #3
cwilkie
Chance
cwilkie's Avatar
movement
I know it moves more than that so I guess my block needs to be bored. To the best of my knowledge the block has never been bored so it is standard. When I bring it to the machine shop how much should I get it bored? I would like to to be as minimal as possible.
BB 396 w/TH400
BB 496 w/TH400
Old 09-06-2005, 07:04 PM   #4
jamal
jamal's Avatar
if it runs good and doesn't have blow by I would run it.
67 chevy stepside, 6 cylinder, three on the tree, small window. Currently in resto.
jamal is offline   Reply With Quote
Old 09-06-2005, 07:20 PM   #5
cwilkie
Chance
cwilkie's Avatar
blow by
The motor runs good but there is a slight noise and the tops of the pistons are black. The inside of the tail pipes are also black.
Chance
BB 396 w/TH400
BB 496 w/TH400
Old 09-06-2005, 07:55 PM   #6
lowrider79
Is the black wet? If it's not wet it's probably just carbon from the motor running to rich. Did you do a compression check acro all of the pistons before you tore it down?
lowrider79 is offline   Reply With Quote
Old 09-06-2005, 08:21 PM   #7
neonlarry
neonlarry's Avatar
As far as how much to bore it, leave that up to the machine shop. They will mic it and see exactly how much it will take to get the bores back to round again. In other words it depends on how much they are worn. .020 would be ideal .040 would hopefully be max, that way you have some left to rebuild again.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
