09-07-2005, 01:54 PM | #1 |
Magnificent bastard
? for guys with rear discs
I put a kit on my Sub's 12-bolt last weekend, along with a disc/disc proportioning valve. In the process I also discovered my master cylinder was bad, so I replaced that. So anyone with rear discs, is your pedal soft? Mine is softer than before, but it stops way better, also. I may need to bleed some more, but I was wondering if a soft pedal is pretty much normal with rear discs or not. Thanks!
1977 Big Block Burb |
09-07-2005, 02:01 PM | #2 |
when you say "soft" do you really mean easy b/c i notice the pedal felt diffrent in my truck but not really soft so i have kind of just chalked it up to the fact it doesnt take as much force from me to stop the land sled anymore
square body trucks an addiction or an investment either way they consume all my extra time and money |
09-07-2005, 02:14 PM | #3 |
Magnificent bastard
Well, I can push the pedal all the way to the floor if I want to, but the truck will stop easily before it hits the floor. I may try to bleed it some more. I had the whole system apart, there is probably still some air in there someplace....
1977 Big Block Burb Last edited by Bad Karma; 09-07-2005 at 02:15 PM. |
09-07-2005, 03:14 PM | #4 | |
where did you get your disc conversion kit at? did you buy calipers from something else? do you like the quality? was it an easy install? alot of questions, i know, but i think many of us are considering this
1987 350 TBI lowered 5/7 |
09-07-2005, 03:40 PM | #5 |
*Proud Member*
i too have rear disc setup and the disc/disc proportioning valve and my truck's petal doesn't seem soft at all... probably just a lil air in the lines...
how'd your install go? |
09-07-2005, 03:50 PM | #6 | |
09-07-2005, 04:02 PM | #7 |
Magnificent bastard
I got the kit (non-parking brake version) from www.blackwidowperformance.com. Really cool guys, great to deal with. Install was pretty easy, although I did have a problem with one of the banjo fittings leaking, so I replaced the braided lines from the kit with hard line and front brake hoses from a Suburban application, which solved the leaking problem. Not sure why the original banjo fitting wouldn't seal
The quality of the kit is good, 3/8 steel brackets, rotors fit the axles perfectly. Only thing I noticed was that the pads sit above the rotor by about 3/16" or so, but it doesn't affect the braking that I can tell. The truck stops great, I really like how it works (even with the soft pedal). I got the disc/disc proportioning valve from www.performanceonline.com, nice piece, super-fast shipping. Installing it wasn't fun, though. Other stuff I noticed, the bolts supplied with the kit were too long for my application, but a quick trip the the hardware store fixed that. Also, I have steel chrome wagon wheels, and the added thickness of the rotor makes for a little less thread engagement on the lug nuts. Nothing to worry about for mine, but if I had aluminum wheels, I would have installed longer wheel studs. Overall, I am very happy with the kit, and if I can get the air out of my lines, it will be even better.
09-07-2005, 04:13 PM | #8 |
*Proud Member*
i did 2 rear disc fabs for my project... long story...
first off, i have a chevelle axle under the rear of my stepside... it's got the smaller GM bolt pattern on the rear 5x4.75" first set was rear discs from a 98-01 camaro... i custom fabbed the brackets and made them work... the setup was beautiful, with 12" discs... beautiful, until i tried to mount my 15" wheels... doh! back to the drawing board, i made some phone calls and figured out that the previous generation of camaro's used 11.5" rotors... so i went with the complete setup from the rear of a 93-97 camaro, with great results... the axle brackets from the camaro fix, and bolted directly up to the chevelle axle and i wish i woulda known that to begin w/.... woulda saved me 6 weeks! but, overall, after i got my new porportioning valve (recommended by someone on this board) from http://www.inlinetube.com/ i was all set. the setup works great! |
09-07-2005, 04:14 PM | #9 |
Magnificent bastard
Forgot to mention, the reason I replaced the braided lines completely was because I couldn't find a banjo-to-AN adapter locally, and I really wanted to get the truck back together. The braided lines in the kit have a 3/16 flare to -3 AN (I think) adapter on one end so it threads into the stock T-fitting, and then the banjo to -3 AN fitting on the other end, with the -3 AN braided line in the middle (obviously ). To use the braided lines, you have to move the T-fitting to the top of the diff so it's centered on the axle, stock position is off to one side. My Sub is not lowered, so I don't know if moving the T-fitting would cause clearance issues or not...
09-07-2005, 04:19 PM | #10 |
Magnificent bastard
75stepside, that looks great! The rotors from my kit were double drilled for 5 on 5 and one pattern a little smaller, must be 5 on 4.75... Here's an actual pic of the kit I received (they asked me if they could use it at a hot rod show before they sent it to me).
09-07-2005, 10:44 PM | #11 | |
Happy to be here
09-07-2005, 11:01 PM | #12 |
anyone on here used this board members stuff?
http://www.blackbirdscustomtrucks.com/index7.html looks decent enough....
09-08-2005, 10:49 AM | #13 | |
Magnificent bastard
09-08-2005, 10:37 PM | #14 |
You get what you pay for
Here you go. This is a article I was writting for Jeff to put on www.73-87.com but never sent to him. I just uploaded the whole folder so everything is in it I was going to use for his site. I haven't read it or done anything to it since writting it long ago. Anyway, there is a link in the article to download a zip file of the fullsize templates. In the zip file it will have instructions on how to print them out so they will be the correct size. Take my word for it, if you can find someone who has a CNC or laser cutter, have them cut. It's a PITA to do it the hard way like I did.
http://www.73-87.com/7387garage/chas...n/reardisc.htm Oh, and Jeff, you can have all this if you still want it. Everything I have on it is in the disc folder. Mike Last edited by swervin ervin; 09-09-2005 at 06:23 PM. |
09-08-2005, 10:58 PM | #15 | |
yeller
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
09-08-2005, 11:01 PM | #16 |
Jeff, move it to a folder of your choice. I think it would look a little strange in the mike directory.
09-09-2005, 08:44 AM | #17 | |
yeller
http://www.73-87.com/7387garage/chas...n/reardisc.htm Hope you don't mind, but I fixed some spelling errors and changed the non 73-87 links to open in a new window. Also, can you update your post with the original link to point to the new location? Just want to avoid any confusion for others.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale Last edited by bigblock73; 09-09-2005 at 08:45 AM. |
09-08-2005, 11:04 PM | #18 |
Project92 SWB stepside
I just put disc onto my Dana60. This is under a 92 SWB truck. I think you need to bleed more. My pedal is very solid!! Im sure you realize the proper order in which to bleed??
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448 |
09-09-2005, 06:25 PM | #19 |
You mean to tell me I had speeling errers??
Thanks for fixing everything. I wrote the article long ago as you know and really hadn't prove read it or anything. Mike |
