Old 09-07-2005, 05:01 PM   #1
rchdrm
The start of the $ pit!
rchdrm's Avatar
Help removing rocker panels
Before I tear things up can someone tell me how to remove my old rusted rocker panels? I have a 68 c10
rchdrm is offline   Reply With Quote
Old 09-07-2005, 05:39 PM   #2
matthufham
they should be held on with adhesive on the pillars, and spotwelded to the inner rockers and floorpan. there's probably a correct way of removing them, but i just took a sawzaw to the cab the last 2 times.
matthufham is offline   Reply With Quote
Old 09-07-2005, 06:27 PM   #3
Frizzle Fry
Frizzle Fry's Avatar
Drill out all the spot welds. If they are hard to see, going over the welds with sandpaper will make them more visible. Use a small bit for pilot, then larger. Try not to drill any deeper than required to break it loose.
Frizzle Fry is offline   Reply With Quote
Old 09-07-2005, 06:32 PM   #4
cableguy0
after fighting with the spot welds for about 1/2 an hour i got frustrated and grabbed the air chissel. i removed both rockers in the course of about 5 minutes without damaging the surrounding metal
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 09-07-2005, 09:07 PM   #5
camaro__thunder
Epoxy Primer Friendly
camaro__thunder's Avatar
how to get rid of those rusty rockers
BAGS/BODYDROP/Z..... the works
My Project 69 SWB
SHAVED BAGGED DOORED
camaro__thunder is offline   Reply With Quote
Old 09-08-2005, 12:24 AM   #6
SCOTI
SCOTI's Avatar
Don't help too much . . ....
You will need to drill out the spot welds & do some grinding. You can make it easier to find the spot welds by scuffing the whole bottom of the jamb w/some coarse scotch-brite or sand paper.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-08-2005, 07:44 AM   #7
68C15
blood type; Retumbo
68C15's Avatar
they are glued in ?!
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 09-08-2005, 09:07 AM   #8
chevyfarmer
chevyfarmer's Avatar
I have never seen a set glued in. They have always been spot welded on the trucks that I have worked on. Eastwood has a good spot weld removal tool. Really like the airbag idea..... grind them off in style!
67 short wide 355ci 3 on tree
69 short wide 250ci 3 on tree
68 long wide 283 3 on tree
72 2wd Blazer project 454 5 speed
chevyfarmer is offline   Reply With Quote
Old 09-08-2005, 10:21 AM   #9
SCOTI
SCOTI's Avatar
The 'glue' is just seam sealer.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-08-2005, 01:09 PM   #10
panhandler62
Java Mechanic
panhandler62's Avatar
Mine are held on with screws and I don't even have inner rockers.... LOL
Keith
11 Lincoln MKT -- Momma's wagon
13 G37xS -- middle age crazy car
68 C20 Fleetside -- RIP
Decorating the whole town up at a cost of $27 ....
panhandler62 is offline   Reply With Quote
Old 09-08-2005, 01:36 PM   #11
68haywagon
I'm watching you!
What's a rocker The rust removed mine
2012 Chevrolet Silverado 1500 Z71 4WD
1993 Chevrolet C-1500 W/T - Blue - 4.3L V-6, 4 speed auto - Dad's (RIP)
1992 Chevrolet S10 - LS swap project
1968 Chevrolet C-10 longbed fleetside - sold
68haywagon is offline   Reply With Quote
Old 09-08-2005, 01:41 PM   #12
dubie
dubie's Avatar
I just used a die grinder and cut the spot welds to remove the rocker. Took 15 minutes to do both sides
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 09-08-2005, 01:45 PM   #13
RPOZ11
72 BB C30 Super LongHorn
RPOZ11's Avatar
I am doing mine on a cab shortly...
How many spot welds are there usually and their locations thru the areas?
Thanx!
72 BB C/30 Longhorn Super
HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM
HO72 build :
http://67-72chevytrucks.com/vboard/s...d.php?t=714492
2017 SS
RPOZ11 is offline   Reply With Quote
Old 09-08-2005, 02:37 PM   #14
edmonton72
Nothings as cool as my 72
edmonton72's Avatar
My passenger side is worse, i remember laugh and telling my dad that i could see the road through the floor when we were driving it home.
1972 C10 Longbox
In the middle of body off restoration
Rebuilt 355, turbo 400, 3.42 12-bolt
Rolling chassis finally done and cab mounted. Now onto sanding, bondo and more sanding.
edmonton72 is offline   Reply With Quote
Old 09-08-2005, 05:27 PM   #15
matthufham
i used the word adhesive, same thing
Old 09-08-2005, 08:10 PM   #16
Shane
Shane's Avatar
never seen one with "seam sealer" ... all spot welds ... across the pinchweld at the bottom and a couple on each end
Shane is offline   Reply With Quote
Old 09-08-2005, 10:01 PM   #17
lowrider79
Thanx!
About 1 billion
or so it will seem. There on the bottom seam, on the top by the sill plate on the rear going up the side of the cab, on the front by the pillar. Basically everywhere that the rocker touches the cab.
lowrider79 is offline   Reply With Quote
Old 09-08-2005, 10:14 PM   #18
Daxcor
Daxcor's Avatar
spot weld cutter
A good sharpe spot weld cutter instead of a bit will do a lot less damage to the remaining metal.
Brad
Daxcor is offline   Reply With Quote
Old 09-08-2005, 10:18 PM   #19
rchdrm
rchdrm's Avatar
got one started
Thanks for the input! I too like the idea of dropping it and letting the road take over but that would add even more dollars to the money pit.
Just so others know I took a few photos of the project. Not a step by step but I can do that on the next one.
I just used a chisel and knocked the welds loose. Too many spot welds to drill out. Probably one every 1/2 inch or so.
Hope this thread may help others.
