09-07-2005, 08:51 PM | #1 |
disk brake conversion + lowering frunt
i have a 69 2wd C10 and i want to put disk brakes up frunt. i know u can take controle arms and spindles off of some newer model trucks(or so my uncle tells me) and i was wondering what years work and dont work?? and i also want to lower the frunt 2-4 inches so what would yall recomend?
thanks |
09-07-2005, 09:05 PM | #2 |
I put spindles and disc brakes from a 1972 C10 on my 1969. I used drop springs on the front and rear
09-07-2005, 09:29 PM | #3 |
I've seen people posting that they used the entire crossmember from models all the way up to 1980 something...they seem pretty good about interchange (goes well with the interchangability of the Chevy small block, huh!).
09-08-2005, 12:18 AM | #4 |
You can use 71~87 disc brake stuff. You'll want to make sure to get the 1.25" thick rotors vs. the LT duty 1" rotors found on some of the later models.
As for lowering, since you'll already be swapping to disc brake spindles, just get some new drop spindles from BellTech or WesternChassis. You can add some 2" drop springs or trim 1 coil off the stock ones if on a budget.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 09-08-2005 at 12:19 AM. |
