Old 09-07-2005, 10:18 PM   #1
CareTaker
CareTaker's Avatar
68 Rear Wheel Bearings
Have a 68 GMC pick-up that has blown rear seals in the axel. I have some concern with the rear axel bearings being shot as well. According to the book there are three kinds of bearings: drop in (easy to do), press in (still easy for me to do ), and machine pressed in (need to go to the dealer or garage to have them do it).
My question: how can I tell if the bearings are press in or machine press in. Short of wailing on it with an impact hammer and seeing if I can get them out?
Many thanks!!
"You have the rest of your life to solve your problems. How long you live depends on how well you do it." -Clint Smith
Me - 1972 Chevy Blazer 4x4 with a 6" lift
Her - 1968 Pickup daily Driver soon to be a Street Rod
CareTaker is offline   Reply With Quote
Old 09-09-2005, 10:22 AM   #2
dennislbrooks
dennislbrooks's Avatar
axle bearing
I am awaiting feedback on your question also. Since the axle housing is not removed normally, I guess that a 2 finger inside bearing puller will be needed, then to install the new one---use a bearing installer or a large socket to evenly tap it in. It should be a flat roller type. They do make a repair bearing if you have surface wear on the axle. I think it is p/n RP6480.
dennislbrooks is offline   Reply With Quote
