Old 09-08-2005, 02:25 PM   #1
86swb
Born a Chevy Man
86swb's Avatar
Back up light will not work on Burb
I know the bulbs are good and the same goes for the fuse. What else could cause the back up lights not to work. Where do I look for the problem? Thanks
John or 86 (Viet Nam combat Vet-BIG RED ONE) '65-'66
*1986 Chevy SWB Silverado
*1984 Chevy Longbed Silverado
New Kia Sportage (Wife's car and she loves it)
CHEVY, American made w/pride!
If you can read this, YOU NEED TO THANK A TEACHER!
If you can read this in ENGLISH, PLEASE THANK A SOLDIER!
GOD BLESS AMERICA AND BLESS OUR FIGHTING TROOPS
86swb is offline   Reply With Quote
Old 09-08-2005, 02:38 PM   #2
farside847
farside847's Avatar
What kind of tranny do you have? A 3 on the tree has the backup switch on the column. That switch breaks easily.
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree
farside847 is offline   Reply With Quote
Old 09-08-2005, 05:29 PM   #3
86swb
Born a Chevy Man
86swb's Avatar
It is an auto 350 trans.
Old 09-08-2005, 06:23 PM   #4
hilljob26
hilljob26's Avatar
chevk your neutral safety switch,thats where my backup lights connect to,it is either bad,or it needs moved side to side,its kinda touchy
21 2500hd duramax
58 apache
HILLJOB GRAPHIX--for all your graphic needs
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=542497
LS ENGINE SWAP INFORMATION THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=377348
4l60 to an NP205
http://67-72chevytrucks.com/vboard/s...43#post3697343
hilljob26 is offline   Reply With Quote
Old 09-09-2005, 11:00 AM   #5
Shock_Me
Shock_Me's Avatar
After you've checked the neutral safety switch on the steering column, try cleaning the fuse socket. Mine was working intermittently, and that was the problem.
Shock_Me is offline   Reply With Quote
Old 09-09-2005, 11:59 AM   #6
86swb
Born a Chevy Man
86swb's Avatar
Thanks guys, will check these out. Do not know how to check to see if the neutral safety switch is good or bad. How do you tell?
Old 09-09-2005, 01:00 PM   #7
cdowns
cdowns's Avatar
first place i'd check would be the socket// with the key in the on position and the tranny in reverse you should have 12v to the center electrode of the socket if so then you either have a bad bulb ,dirtyy contacts or bad ground if no juice at the socket then check the switch, theres a thin dark green wire that with the key in the on position should be feeding 12v to the backup switch and when the tranny is in rev the 12v comes thru the light green wire to the backup lamps
Old 09-09-2005, 01:48 PM   #8
pjmoreland
pjmoreland's Avatar
If it's just your neutral safety switch that is out of adjustment, your back up lights should come on somewhere in the shifting range. With the key in the "on" position, try shifting slowly through all gears and see if the back up lights come on somewhere other than in reverse. If your back up lights come on somewhere other than in reverse, I'd recommend making sure your shifter linkage is adjusted properly before adjusting the neutral safety switch. You'll know that your shifter linkage is adjusted correctly if you can shift between neutral and drive without pulling back on the shifter lever.
If your back up lights don't come on at all, I'd suspect the screws that hold the metal light housing to the body and provide the ground path.
pjmoreland is offline   Reply With Quote
Old 09-09-2005, 07:31 PM   #9
86swb
Born a Chevy Man
86swb's Avatar
Thanks guys. You have given me lots of things to check out. Will get out tomorrow and see what I can find out. Appreciate all the help. Just love this board.
Old 09-09-2005, 11:47 PM   #10
4x4Poet
Another possiblity to check down the line:
The bulb sockets could have corrosion at the bulb contact points. Easy check with voltmeter. Easy clean up, but watch to not wear down the contact points. I've found contact points on the end of spliceable wires in auto parts stores.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
