Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 09-08-2005, 04:32 PM   #1
BladeX
Exclamation Want to Trade Holley 650cfm for 300-400 cfm carb.
I bought a carb thats wAY to much for engine all it does it flood mu engine lol.it was just barely rebuilt less then 100 miles ago. Its a Holley 650cfm 4brl.
Im lookin for somethin for my engine 305cid somewhere in the 3-4 hundred cfm range. Im on border of TN and KY.
Lemme a message.
BladeX is offline   Reply With Quote
Old 09-08-2005, 05:03 PM   #2
iceman7329
iceman7329's Avatar
I may know some one who can help you, back in a day or two.
iceman7329 is offline   Reply With Quote
Old 09-13-2005, 11:30 AM   #3
motocrosschump
you might want to check your float level or pump psi
2006 Titan SE Crew Cab Daily Driver
2005 Mazda Tribute (Wifes car)
1969 C10 SWB 350/3 Fleet "Max"
1969 Chevelle 2 door 350/3
motocrosschump is offline   Reply With Quote
Old 09-14-2005, 07:11 AM   #4
ChadMorris
Newbie truck Rebuilder!
I have a Holley 390 CFM that I would be willing to sell, it was completely rebuilt.
I'm asking 175.00 shipping included
I had it on my inline 6.
Chad
"Old Blue" 1964 GMC Fleetside in pieces
350 TPI with 700R4 tranny now installed( well kinda propped in place until the tranny crossmember is bolted in !!!!!
1995 Toyota 4runner , 197,000 miles and going...
2007 Honda Odyssey Van (Wifes car)
ChadMorris is offline   Reply With Quote
Old 09-14-2005, 11:17 AM   #5
gn4u2c
gn4u2c's Avatar
650 is a little much but should run fine. with the truck running adjust the floats so fuel is just at the bottom of the sight hole. it should just barley trickle out. on the secondary side you should adjust go 3/4 throttle quick then look and readjust as you need to pull fuel out of that bowl to lower the float. hook up a vac gauge and aadhust the idel mixture for max vac be sure to turn both the same amount 1/8- 1/4 turn at a time most.
You can also step down a few jet sizes this is also easy. check what you have with the floats corrected and good idel mix you may be ok there. Holley are the best carb out there if tunned corretly. Any local performance sho has holley jets .
gn4u2c is offline   Reply With Quote
Old 09-14-2005, 11:44 PM   #6
BladeX
Yeh all that stuff ya said is brain surgery for me....haha
Old 09-15-2005, 01:00 PM   #7
cableguy0
300 or 400 cfm is wayyyyyy too small for a 305 inch motor. your carb just needs adjusted
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 09-15-2005, 05:53 PM   #8
BladeX
I turned it all the way lean and it still runs. It dosnt even cut off.
Old 09-15-2005, 08:51 PM   #9
cableguy0
that floats must be too high and its possible the timing is off as well. the carb needs to be adjusted properly.
Old 09-15-2005, 11:28 PM   #10
BladeX
timing is perfect. i know nothing bout floats.
Old 09-17-2005, 11:36 AM   #11
SSC's76
No No
SSC's76's Avatar
Floats too high and or PV blown. Nothing wrong with using a 650 CFM vac sec carb on a 305. A q-jet in stock for will flow 750-780 cfm of course the demand has to be there to pop the secondaries full open to see that kind of flow.
1976 Custom Deluxe SWB Med FMB.3/4 Drop.
Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out.
1997 K1500 ext cab 5.7 stock except muffler
SSC's76 is offline   Reply With Quote
