Old 04-14-2002, 09:01 PM   #1
Custom 68
Custom 68's Avatar
Post what spark plugs
I hated to ask again but I searched the best I could looking I have seen this posted before. Next time I will print it I have a 327 with HEI what plugs should I run?
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 04-14-2002, 09:27 PM   #2
RipMeyer
RipMeyer's Avatar
Post
I think you would go with stock plugs gapped at .045
RipMeyer is offline   Reply With Quote
Old 04-14-2002, 09:54 PM   #3
MJN
MJN's Avatar
Post
go with what the manual says for HEI .060" gap this will give you the most powerful spark for HEI. .045 and .035 are old fashioned for points. Use AC R45TS plugs, they have given me the best longevity and response in my 350. I like to stick with GM parts since they did come from the factory like that and were tuned for those parts. Just my $.02.
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 04-14-2002, 10:54 PM   #4
cali_surfer
cali_surfer's Avatar
Post
I second the AC plugs, R45 with a .045" gap and you should be stylin'
My engine is stock... trust me ;o)
cali_surfer is offline   Reply With Quote
Old 04-15-2002, 12:16 AM   #5
imdarren
imdarren's Avatar
Post
The question I have is. NAPA sold me AC R44T, and the Chevy Service Manual recomends the AC R44TS. Found out that the "T" is a little shorter, and the "TS" longer (closer to the piston). What do you guys think / recomend? Darren
Washington State
1967 Chevy C10 LWB Rodstoration In Progress.
1972 K20 Cheyenne Super
imdarren is offline   Reply With Quote
Old 04-15-2002, 12:43 AM   #6
cali_surfer
Post
It probably wont make that big of a difference. Only real way to tell on your motor would be to try both. Spark plugs are so cheap it doesnt really matter. But, are you running rich at all? If you are you might want to think about stepping up to R45's... they're a little "hotter" than R44's and I'm pretty sure that the 45's are the OE plug for HEI ignitions.
Old 04-15-2002, 08:33 AM   #7
Custom 68
Custom 68's Avatar
Thumbs up
Great Thanks guys I guess the difference in the plugs from stock to HEI is just the gap. I will get new ones and open the gap up some!
Thanks!
Dae
Dave
