Old 09-08-2005, 11:51 PM   #1
yyyktk1
Question radiator leak
Just noticed the radiator is leaking. I plan on getting a new radiator ($200) but in the meantime I was thinking of using Prestone 'stop leak'. Will this stuff screw up my water pump? It says it is safe but I want to make sure.
Thoughts?
yyyktk1 is offline   Reply With Quote
Old 09-08-2005, 11:56 PM   #2
iceman7329
iceman7329's Avatar
If it was mine, I wouldnt use it. I never use anything that you pour into any part of an engine or transmission.
iceman7329 is offline   Reply With Quote
Old 09-09-2005, 12:01 AM   #3
bagged01extcab
Trey Oney
bagged01extcab is offline   Reply With Quote
Old 09-09-2005, 09:12 AM   #4
Slonaker
Insert Witty Text Here
Slonaker's Avatar
If you plan to get a new radiator soon, and you can get to the leaky part, I would use JB Weld or one of the radiator repair kits that comes with a thick 2 part epoxy that you mix by kneading the two parts together.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 09-09-2005, 11:27 AM   #5
Russell
Professional Grade
Russell's Avatar
I dropped my drill once, and stabbed a hole into one of the rows on my 4 core. Being as it was basically a new rad, I went ahead and fixed it. Still no problems to this day almost 2 years later. I just took my butane soldering torch, got the metal good and hot, then just soldered it shut. Had a bit of a bead sticking out later on that I carefully shaved down with a die grinder, but after I painted it, you'd never see it there unless you were looking for it, and it never leaked once.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 09-09-2005, 12:24 PM   #6
86swb
Born a Chevy Man
86swb's Avatar
Can you use JB Weld? Where is the leak at? If it is where you can put some JB Weld on, then I would do as Slonaker said and put the JB Weld on thill you get the new radiator. Maby after the Weld is done, you might not need a new radiator. JB Weld is great stuff. I had a crack in the fill neck. I sanded, cleaned, the JB Weld over the crack and never has leaked since and that has been over a year ago.
John or 86 (Viet Nam combat Vet-BIG RED ONE) '65-'66
*1986 Chevy SWB Silverado
*1984 Chevy Longbed Silverado
New Kia Sportage (Wife's car and she loves it)
CHEVY, American made w/pride!
If you can read this, YOU NEED TO THANK A TEACHER!
If you can read this in ENGLISH, PLEASE THANK A SOLDIER!
GOD BLESS AMERICA AND BLESS OUR FIGHTING TROOPS
86swb is offline   Reply With Quote
Old 09-11-2005, 08:51 PM   #7
yyyktk1
Jb weld worked. Thanks! It was leaking at the neck.
Old 09-12-2005, 12:42 PM   #8
piecesparts
Parts and more parts
piecesparts's Avatar
So do you have a problem with the oil and water????
piecesparts is offline   Reply With Quote
Old 09-12-2005, 12:55 PM   #9
yyyktk1
Not sure what you mean?
I used the JB weld to repair the neck of the radiator. It was leaking where the neck come out of the core.
Old 09-12-2005, 01:07 PM   #10
iceman7329
iceman7329's Avatar
Yes, I have a big problem with the water and the oil. I run it without them.
No, I mean I woundnt put something other than the water or the oil thats made to be in the engine.
