Old 09-09-2005, 12:27 AM   #1
rico_bob
"Treasure the Ride"
rico_bob's Avatar
Question Upper Control Arm Shaft Repair Need Help!
I need to replace the rubber boots (grease cups) on the upper control arm shafts of my wife's '63 C-10 Pickup. Question, will I be able to change the cups out without compressing the coil spring? Or will there be too much pressure on the upper control arm to do this with dealing with the coil springs. I want to be safe, but I do not have a compressor and would have to rent or buy one.
Any help is appreciated. Thanks! rico
If you think you can you're right. If you think you can't you're still right.
Trucks: '56 SWB; '57 SWB; '63 C-10
Current projects: 1963 Long Fleetside for the wife!
'56 for the daughter.
Visit us at: www.ricos-rods-and-relics.com
rico_bob is offline   Reply With Quote
Old 09-09-2005, 04:08 AM   #2
el curioso
el curioso's Avatar
1. Set it on jack stands to Where the tire is on the air about 2".
2. Remove tire compress spring with a jack (slowly and just enough to remove he upper ball joint castle nut)
3. Lower the jack very slowly and carfully till the spring is completely depresed.
4. Reverse procedure to reassemble.
My.2 cents
el curioso is offline   Reply With Quote
