Old 09-09-2005, 11:40 AM   #1
Frank_Zeller
Frank_Zeller's Avatar
TCI th350 with 32K miles Austin Texas
This is out of my truck in the pictured top left. Short tail TCI th350 with 32K miles on it with a stock stall converter. Still has the big TCI sticker on it. Changed fluid at 18K. 250.00. Went to 700R4. You will need a dip stick tube. Located in Austin Texas.
link to summit info.
http://store.summitracing.com/partd...k=KeywordSearch
These TCI StreetFighter transmissions are durable enough to withstand the rigors of even the toughest street machines. They are ideal for engines producing 450 HP with a non-supercharged system. Equipped with a manual/automatic valve body, most units allow you to manually shift the vehicle into each gear change or, by placing it in the drive position, remain fully automatic. In either mode, you get a racetrack shift that bangs through the gears and shaves time off your ETs. When you use the manual gear selection feature, the StreetFighters upshift and downshift right when you move the lever, with no lag or governor override. When you select the normal drive position, they retain positive automatic shifts, for the ease of driving you look for in an automatic transmission
69 SWB C/10 5-6 drop 700R4
69 Firebird Convert 455 4 spd
70 Torino GT Convert
Austin-Texas
Frank_Zeller is offline   Reply With Quote
Old 09-10-2005, 03:56 PM   #2
scooby3242
scooby3242's Avatar
pm sent
1973 gmc swb
scooby3242 is offline   Reply With Quote
Old 09-10-2005, 07:13 PM   #3
68 chevy truck-TPI
A WORK IN PROGRESS
68 chevy truck-TPI's Avatar
also interested if it has not sold yet. can you figure shipping to 30577?
68 chevy truck-TPI is offline   Reply With Quote
Old 09-10-2005, 11:13 PM   #4
Frank_Zeller
Sale pending Local.
Austin-Texas
Old 09-14-2005, 04:55 PM   #5
Frank_Zeller
Sold
Austin-Texas
