09-09-2005, 02:08 PM | #1 |
wheres the frame VIN???
i took my truck to the sheriffs today to get it inspected,but they wouldn't ok it because it only had 1 vin plate,i thought there was one on the frame as well,there are some #'s stamped on each side right below the door,but they dont match the vin on the door piller,any help would be much appreciated.thanx...mike
21 2500hd duramax 58 apache HILLJOB GRAPHIX--for all your graphic needs My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=542497 LS ENGINE SWAP INFORMATION THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=377348 4l60 to an NP205 http://67-72chevytrucks.com/vboard/s...43#post3697343 |
09-09-2005, 02:12 PM | #2 |
its all about the +6 inches
here
09-09-2005, 02:14 PM | #3 |
Vin #
Sounds like its' time to invest in some letter and number stamps.
09-09-2005, 03:49 PM | #4 |
Ask them to show you, in their book, how many vin plates a vehicle is supposed to have? MOST don't have a clue.
Had nearly the same problem in CA....trying to license my 65 Chevelle SS. I had to show the lady where the door and body tags were......AND where the SMOG equipment is located on my engine (it has none...never did in 1965). I advised her I have added factory CA smog equipment to my SS - added a PCV valve and non atmosphere vented breather for this system (breather plumbed to the clean air side of my open element air cleaner). Original 1965 engines had a draft tube for crankcase evacuation!! |
09-09-2005, 04:03 PM | #5 |
right on,thats all i needed,now its actually legal
