Old 09-09-2005, 04:06 PM   #1
MEANGREEN70
MEANGREEN70's Avatar
Lower Control Arms (help)
building a 70th chevy, iam bagging it and i would like to know if i can use the stock arms or do i need to get aftermarket ones. if i can use the stock ones do i need to do any modifications to then. I also would like to see pics of anybodys front suspension.
MEANGREEN70 is offline   Reply With Quote
Old 09-09-2005, 04:56 PM   #2
DM310
Yes you can use you stock arms. If you look you will find some pics on the forum. check out www.***************** for bag cups and plates
66 C10 (under construction)
1.5" crossmember drop
2" Z'ed frame
8" rear notch
Watts-link
Bagged
DJM 3" spindles
DM310 is offline   Reply With Quote
Old 09-09-2005, 04:56 PM   #3
XXL
Seņor Member
XXL's Avatar
Stock lower arms are fine. Cups are needed (dissenting opinions in 3... 2... ). Only mod required will be to remove the steel bump/steering stop bracket.
XXL is offline   Reply With Quote
Old 09-09-2005, 05:11 PM   #4
MEANGREEN70
Rear Shocks
thanks for the info guys, one more thing what kind of rear shocks the you guys use.
Old 09-09-2005, 08:51 PM   #5
XXL
Seņor Member
XXL's Avatar
Monroe 32207 or Gabriel 82007... $25-30 each.
Old 09-10-2005, 10:49 PM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
.....if i can use the stock ones do i need to do any modifications to then. I also would like to see pics of anybodys front suspension.
That depends on what spindle you are going to run. If you go with a 3" spindle and 15" wheels you will have to mod the stock A-arms. They will need to be trimmed or they will rub the rim at full lock....
Here's my 82 Blazer before I changed to a Scott's IFS...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 09-10-2005, 10:52 PM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
And my 77 Cheyenne....
Old 09-12-2005, 09:00 AM   #8
MEANGREEN70
NSTRUX, iam going with 20inch wheels
Old 09-12-2005, 03:15 PM   #9
MEANGREEN70
N2TRUX, did you weld the lower cups to the arms?
