Mig off ebay
Hey I just baught this on ebay. Never used wire before pretty good with stick. Tell me if this is a good deal and if good for sheet metal work? paid $335 for it
NEW SP-125 Plus is not like the Weld-Pack 100 it's a real welder. this unit is backed by a 3year warranty from Lincoln. Combination Wire Feeder/MIG and Flux-Cored Welder List Price:699.00 (USD) SP-125 Plus 115/1/60 The SP-125 Plus combines a wire feeder and welder with features that allow anyone to make great welds! It is one of the few portable, MIG and flux-cored packages on the market to feature continuous voltage adjustment for tight procedure control. With a convenient 115V input and 125 amps of welding power you can weld a multitude of applications from home and farm repair projects to body work in automotive shops. Also great for welding stainless steel and aluminum. Advantage Lincoln • For welding steel, stainless steel and aluminum. • Package includes gun and cable, work clamp and cable, input power cord, guide tubes and drive rolls, gas solenoid valve, gas regulator, and spool of wire. • 115V operation-no special wiring required. • Solid State output control for long life and repetitive welding applications. • Designed for.023?-.030? solid MIG wire and .035? flux-cored wire. • For welding 24 gauge through 5/16? mild steel plate. • Suitable for welding with .023?-.035? stainless steel and .035" aluminum. Physical specifications Weight:54 lbs. (24.3 kgs.) Dimensions (in) HxWxD:12 x 9.75 x 16.5 Dimensions (mm) HxWxD:305 x 248 x 419 MIG Flux-Cored Options include with this welder Deluxe Adjustable Gas Regulator and Hose Kit Welding Specifications Rated CV Output Amps/Volts/Duty Cycle Output Range Wire Feed Speed Range (IPM) Wire Feed Speed Range (M/MIN) Solid Wire Size Range 90/18/20% 23-125A DC 50-400 1.2-10.2 .023-.030" |
Nice welder, I have the same one. (I paid alot more than you did) so you got a great deal. Very easy welder to use with some practice. It does some clean welds.
67-72 Addict!
Lincoln=QUALITY!
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
