Old 09-10-2005, 06:33 AM   #1
crustysarge
Door Adjustment
The 72 pass door has to be pushed down a little to close correctly and requires some "slamming" effort. The top of the latch on the door is hitting the striker plate on the cab. See the picture.
How do I adjust this. Easily...
crustysarge is offline   Reply With Quote
Old 09-10-2005, 07:30 AM   #2
chops333
i had same problem changed hinges played around with it going from upper to lower door to cab finally got back hope this helps
chops333 is offline   Reply With Quote
Old 09-10-2005, 08:06 AM   #3
lowrider79
Adjust the striker plate on the cab. Raise the striker plate by loosening the 4 bolts and move it up. I would only loosen the bolts slightly and tap the striker plate upwards with a hammer. The striker plate can move many directions and they can be a real pain in the ... so only adjust it slightly or your problem can get worse. If your not comfortable doing this bring it to a body shop. They can adjust it in minutes.
lowrider79 is offline   Reply With Quote
Old 09-12-2005, 02:15 PM   #4
crustysarge
Thanks lowrider, that did the trick with min headache, took 10 minutes including the wrench getting time. Closes like new now.
Old 09-12-2005, 06:18 PM   #5
lowrider79
Cool I'm glad it worked for you.
