Old 09-10-2005, 09:48 AM   #1
Rear widow won`t close all the way
The rear window`s acting up.Some times it won`t go all the way down.But,mostly it won`t close completely.At firast,someone could go back and help it.Now,that doesn`t work.Could aging weatherstrip/channels be giving too much resistance?I cleaned and put di-electric on all contacts back there.Any ideas?
Old 09-10-2005, 12:54 PM   #2
sameyrasmea72
sameyrasmea72's Avatar
The weatherstrip/ channels are a good place to start. Take the rear pannel off and use a flash light to see the side channels. There is a good chance the felt is peeling off and clogging them up.
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 09-11-2005, 08:21 AM   #3
a28doc
'87 V20 4x4
a28doc's Avatar
the motor also may be weak and need replacing good luck Doc
'86 K5 Blazer 4x4 FOR SALE
'87 v20 4X4
'99 S10 Blazer 4X4
a28doc is offline   Reply With Quote
Old 09-14-2005, 07:50 AM   #4
Do motors do that?I wondered if that was a posibility.
Old 09-14-2005, 09:26 AM   #5
a28doc
'87 V20 4x4
a28doc's Avatar
Mine got to the point it would go sown but for the life of it it wouldnt go up unless I hooked a battery charger to the motor wires it was like it lost one side of the motor
Doc
'87 v20 4X4
'99 S10 Blazer 4X4
Old 09-15-2005, 12:56 PM   #6
Thanks,that`s probably it.I`ll replace the weatherstrip/channels,too.
Old 09-15-2005, 01:46 PM   #7
a28doc
'87 V20 4x4
a28doc's Avatar
I have a brand new window luft motor Id be willing to sell ya for 50 + shipping if you need it they usu run almost 70 or so at parts store let me know Doc
'87 v20 4X4
'99 S10 Blazer 4X4
Old 09-22-2005, 09:39 AM   #8
Is this motor different from a door window motor?I just saw your offer,a28doc.Is yours a GMpart?
Old 09-22-2005, 12:59 PM   #9
a28doc
'87 V20 4x4
a28doc's Avatar
they are a little bigger due to more window weight to raise. I got mine from autozone if I remem right it cost me 65 + tax and that was with my discount of 10%
Doc
'87 v20 4X4
'99 S10 Blazer 4X4
Old 10-06-2005, 09:33 PM   #10
I have a working`86 Suburban one,but danged if they ain`t diff`nt.Sheeyucks!!
Old 10-08-2005, 07:18 PM   #11
I put a new motor in and it didn`t fix it.What`s the best way to pop the switch off the dash?Are the prongs on the sides or top and bottom?
