09-10-2005, 10:54 AM | #1 |
Java Mechanic
Please help with panel wiring
I screwed myself up here.
I had a three-holer panel that I am replacing with a full set (not a tach/vacume, just the regular full instument set) I got the tip page from GMCPaul and popped all the wires out of the lom plug. When I went to put them back in the new places I ran into a couple problems. 1) There are two tan wires.. I did not realise I needed to keep track of which was which until it was too late... 2) I do not have a black w/ white stripe wire 3) I have two dark blue wires of identical shade 4) I have a dark brown wire 5) I do not have a black w/brown stripe I can't make sense of this when I look at these instructions -- ========================================================= Swapping A Idiot Light Dash Out To Gauge Dash The following is for a gauge dash this gives the numbered position of the wires in gauge dash and followed by what it supplies, then number from idiot light dash you move wire from. 1-Black with white stripe (alternator) This runs from the 12 R from voltage regulator and should have a inline fuse. 2-Tan (Brake warning light) Original position 2 3-Pink (Fuel Gauge) Original Position 7 4-Tan(Fuel Gauge) Original Position 4 5-Empty(not Used) 6-Dark Green (Temp. Gauge) Original position 5 7-Black(ground)Original Position 6 8-Gray(cluster light feed) Original Position 12 9-Medium Blue (Right turn) Original Position 11 10-Lt. Blue (left turn) Original Position 10 11-Lt. Green (high Beam indicator) Original Position 9 12-Black/w brown stripe use wire ran from the junction block near battery mounted to passenger side fender with a inline fuse located at junction block end. Remove the wires from your loom plug and place the colors in the # on plug that corresponds with the color from list above. You will need to replace your idiot light temp. gauge for a temp. sending unit with gauges. The black and white wire feeds from the 12gRed wire off back of alternator and requires the use of 2-4amp inline fuses, this wire you need to make and run. The DARK BLUE wire that was originally in #1 position should be deleted because this was the idiot light for the oil pressure. If you need more info. ask
Keith 11 Lincoln MKT -- Momma's wagon 13 G37xS -- middle age crazy car 68 C20 Fleetside -- RIP Decorating the whole town up at a cost of $27 .... |
09-10-2005, 03:08 PM | #2 |
Java Mechanic
Hmmm... I guess I'm not alone in being baffled... lol
09-10-2005, 06:14 PM | #3 |
Java Mechanic
Let me try bieng more specific and see if it rings a bell for someone.
After fussing around for a while I identified which of the two blue wires is superfolous and which is the right turn signal and everything works except the ammeter. In position 1 I have a dark brown wire (cause it didn't go anywhere else.. lol) and in position 12 I have zippy. Am I suppose to run the wire for position 12 myself, or do I scavenge it from the harness somewhere? Has anyone done this conversion before?
09-10-2005, 06:47 PM | #4 |
member #16
sounds like you have to add this wire. This diagram will show the ammeter wires. Hope this helps. Good luck John
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
09-10-2005, 07:51 PM | #5 |
Java Mechanic
That clears a lot up.. Thanks bunches..
