Old 09-10-2005, 05:48 PM   #1
70GMCer
70GMCer's Avatar
Rear Slider Install ?
I have an older slider that I want to install into my truck. I got it used and came with the window seal. Both are in good condition. My question is, will the window seal for our trucks work with the slider? The reason is, my stock rear window seal has the chrome in between and I would like to retain that with the slider if possible.
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 09-10-2005, 06:46 PM   #2
71Dragtruck
71Dragtruck's Avatar
When I had my back window removed and slider installed they used the same seal, so I would say yes.
71Dragtruck is offline   Reply With Quote
Old 09-10-2005, 06:49 PM   #3
cdowns
cdowns's Avatar
yes
Old 09-10-2005, 07:02 PM   #4
hilljob26
hilljob26's Avatar
when i installed my rear slider,i also used the chrome trim,but i had to install the rubber,then install the chrome in the rubber,once that was in,it was fairly rigid,and installation was a snap,i hope this helps
21 2500hd duramax
58 apache
HILLJOB GRAPHIX--for all your graphic needs
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=542497
LS ENGINE SWAP INFORMATION THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=377348
4l60 to an NP205
http://67-72chevytrucks.com/vboard/s...43#post3697343
hilljob26 is offline   Reply With Quote
Old 09-10-2005, 07:12 PM   #5
70GMCer
70GMCer's Avatar
Thanks guys....that's what I needed to know.......
1997 GMC Sierra Ext
1965 Mustang
