Old 09-10-2005, 11:34 PM   #1
dwjack
Truck won't start
Got a problem with my truck. While driving around Thursday I noticed the amp meter drop to 0 three times for about 10 seconds before coming back up. When I got home I shut the truck off and when I went to start it, it was dead.
I have a powermaster one wire alternator that's only about 1 year old and I thought I might have a problem with it. I tried jumping the truck but nothing. I charged the battery fully and it tests good but still nothing. When you stick the key in, the dash lights come on and it buzzes weakly but won't start. To make sure it wasn't the battery I swapped it with a brand new one I had and It does the same thing. There's not enough power to turn the headlights on or roll up the windows which seems like a battery problem.
I tried jumping it strait to the starter and was able to get it to turn over for short bursts before it stopped but it wouldn't start.
Anybody have any ideas for me to try?
1984 Silverado C10
GM Goodwrench 350
Edelbrock Intake/Carb
Hedman Hedders
700R4 Transmission
12 Bolt out of an 81
275/60/15 Centerlines
dwjack is offline   Reply With Quote
Old 09-10-2005, 11:38 PM   #2
iceman7329
iceman7329's Avatar
Make sure all battery cables are tight and ground wires going to frame also.
iceman7329 is offline   Reply With Quote
Old 09-11-2005, 01:51 AM   #3
milehightoyz
AttentionDeficitDisorder
milehightoyz's Avatar
im no electrical expert but sounds like you may have had a short somewhere. popped a fuseable link perhaps? im sure others will chime in with more info.
milehightoyz is offline   Reply With Quote
Old 09-11-2005, 08:33 AM   #4
a28doc
'87 V20 4x4
a28doc's Avatar
these trucks are notorious for the inline fuse up on the firewall for going bad which will cause exactly what you are describing it is located at the top of the firewall near the middle of the truck is just off a connector block there hope this helps
Doc
'86 K5 Blazer 4x4 FOR SALE
'87 v20 4X4
'99 S10 Blazer 4X4
a28doc is offline   Reply With Quote
Old 09-11-2005, 10:41 AM   #5
Scrubby
Check out GMTrucks.org
If the battery is good, then my guess is battery cables.
Scrubby is offline   Reply With Quote
Old 09-11-2005, 01:36 PM   #6
dwjack
The inline fuses at the firewall and starter look good and I have 12.4V at the battery, the starter and the firewall. And I grounded it both off the battery and frame so I don't think its a ground issue or battery cable issue.
Any other ideas?
Old 09-11-2005, 03:10 PM   #7
canadian trucker
A day should have 30 hours.
is the solenoid at the starter ok
just an idea other than that sorry no clue
canadian trucker is offline   Reply With Quote
Old 09-11-2005, 06:09 PM   #8
wetback79c
check your main power cable to the starter make sure it didnt touch the exaust maniful and is shorting there i had a problem like that before and that is what i found it was
wetback79c is offline   Reply With Quote
Old 09-11-2005, 09:48 PM   #9
a28doc
'87 V20 4x4
a28doc's Avatar
also might be the ignition switch in the column but I still think its an inline fuse maybe the inline fuse down by the starter good luck electrical can be very aggravating
Doc
'87 v20 4X4
'99 S10 Blazer 4X4
Old 09-15-2005, 01:41 PM   #10
dwjack
Figured out what the problem was. The ignition module in the distributor was bad. Got a new one and it fired right up.
