Old 09-11-2005, 06:06 AM   #1
hobbz
hobbz's Avatar
good rear bag setup???
been doing some primary hunting and reading, and i was wondering if this would be a good setup?
here are the bags and brackets:
http://www.suspensionconnection.com/...C.html#ITEMIMG
here is the compressor and crap:
http://www.suspensionconnection.com/...scon/2158.html
also has anyone ever deals with that company or know any cheaper prices?
im not worride about tanks right now because it will only be adjusted when i pull.
Hobbz-Garage
1987 Short Step 350/350
hobbz is offline   Reply With Quote
Old 09-11-2005, 02:03 PM   #2
a squarecan
Can we assume you are not planning on on dropping your truck? If you are just using as an overload spring then that is a good basic set-up. If you are using to drop your truck air over leaf is not a good way to go at all.
Keith
a squarecan is offline   Reply With Quote
Old 09-11-2005, 08:16 PM   #3
hobbz
hobbz's Avatar
well i was wanting to use it to lower by taking all my leafs out but 2, so why would this setup not work? explain a lil please.
Hobbz-Garage
Old 09-11-2005, 09:10 PM   #4
70short/step
70short/step's Avatar
Isnt that the same setup as NU2TRX
For every person with a spark of genius, There are a hundred with ignition trouble.
70 Short/Step
70short/step is offline   Reply With Quote
Old 09-11-2005, 09:15 PM   #5
hobbz
hobbz's Avatar
i believe n2trux setup uses firestone F9000 bags? which i thought would be sinilar to these. maybe i am wrong? this will be the first time i have ever worked with air ride and only know what i read....
Hobbz-Garage
Old 09-11-2005, 09:18 PM   #6
70short/step
I dont know anything about bags either. I just thought they looked the same as what you were showing and what he had. Just PM him and ask him since he knows what works.
70 Short/Step
