My Power Steering quit working and I am looking for some advice on what component to replace first. Is it more likely to be a bad pump or bad steering gear?
------------------ K20 LWB Project C20 LWB Wannabe Owner C10 SWB Wannabe Owner River Falls, WI
Eric 1969 K20, 465/205 package |
![]() Join Date: Mar 2001
Might need some more details...like:
No assist? Squealing? Did you check the fluid? Any work done recently? To the p/s assm. If the pump is not making pressure, take the back of the fitting (the one with the high pressure hose fits into) out of the housing and clean that part really good, there is a little screen in there that might just be plugged up. There is a big screen behind this. Could also be the pump is just shot.
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi See it at www.prismnet.com/~grzanich |
its all about the +6 inches
I would blindly blame the pump thoguh.
------------------ '69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it. FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite. If you need a pic posted, E-mail me at longhornmail@yahoo.com Andy, in Columbus Ohio |
if you fluid is up then I would look to the pump as the gear boxes usually don't go bad. They may wear out a bit and get loose or leak but thats about all that goes bad on them. The pump however can stop pumping out pressure.
------------------ 71 basic C-10 350. The only option is the rust.No nothing on it, but thats all about to change. <A HREF="http://www.geocities.com/stevemau/slam33page.html?1004806705410 " TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410 </A>
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html " TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410 </A> |
Recovering Truck Driver
uuhhh, stupid question here, but a good place to start. Is the belt on???
------------------ Ol' Buck: '72 Chevy 1/2T 4x4 shortbox stepside 350/350auto on '84 ralleys and 31/10.5s Angel girl: 67 Cutlass convertible 330, 3spd stick Greener: 90 GMC Jimmy 350/auto Chad Stephens Orleans,NE no name yet: 72 442 under serious construction
67 K-20 350, SM465, Eaton rear, 4.56 no spin option 00 Dodge 2500 4x4, 24V cummins, 5 speed Chad South Central Nebraska |
LOL, I was just thinking that myself!
Thanks for the help guys. I'm going to start with the pump, as all of the obvious stuff seems Ok.
![]() Join Date: Dec 1999
Id blame the pump first its cheaper,pull it apart.Ive never had a bad pump,had some sloppy leaky boxes before though.but never a pump go out,they are easy to take apart,and not very expensive for another,or a rebuild kit.Any beginning trucker can do one!!!
