Old 09-11-2005, 05:30 PM   #1
shifty
Questionable
shifty's Avatar
what is this?
What's this cable that criss-crosses under my tranny/driveshaft and connects to the trailing arms? One end of it actually comes through into the firewall. I thought it was the e-brake, but I don't see how it'd be connected to the e-brake.
Is it necessary?
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 09-11-2005, 05:34 PM   #2
70short/step
70short/step's Avatar
That is definitly your E-brake cable!
For every person with a spark of genius, There are a hundred with ignition trouble.
70 Short/Step
70short/step is offline   Reply With Quote
Old 09-11-2005, 05:35 PM   #3
alf1096
alf1096's Avatar
I second the E-brake cable
alf1096 is offline   Reply With Quote
Old 09-11-2005, 05:35 PM   #4
cableguy0
yup sure is the ebrake.should go across the trailing arms and into the backing plate for the rear drums
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 09-11-2005, 05:41 PM   #5
shifty
Questionable
shifty's Avatar
So, I take it this thing isn't safe to cut...
I need to cut out the middle of my manual tranny xmember, but the cable passes right through the area I wanna cut. ARGGHHH.
I have been fighting with this thing for almost 8 hours over about 4 days (started 2 weeks ago). I bought an angle grinder, air hammer, cutoff tool, all kinds of crap and I just can't seem to cut it off or bust the rivets out. It's buried right underneath the tranny hump (really far forward) so I can't get the top rivets out without taking off the cab or cutting the xmember in half.
Old 09-11-2005, 05:45 PM   #6
cableguy0
pull the transmission out just unbolt it from the bellhousing and get it out of your way. things will be a ton easier with the tranny outta the way and work from there. shouldnt take but 20 minutes or so to have the tranny on the ground
Old 09-11-2005, 05:50 PM   #7
70short/step
I am not sure I follow, but are you saying that after you cut the cross member the cable will still be in the way?? Or is it just in the way to make the cut? You can disconnect it with th adjustment nut in your pic and then just reinstall it when your done.
70 Short/Step
Old 09-11-2005, 05:50 PM   #8
shifty
Questionable
shifty's Avatar
trying to make the cut.
cableguy0, tranny is out. i'm talking about the tranny xmember. This is what I'm looking at right now:
http://www.satellitehead.com/images/...nup1%20(3).jpg
Sorry for the large picture -
So, you see, the rear rivets up top are under the cab/tranny hump with ~1" or less of clearance to get to them. The front top two rivets have abou 2-3" clearance, although it looks like more in the picture.
If you look closely you can see the start of the e-brake cable X on either side of the xmember.
I hate to cut this thing in half, it's in great shape, but it is impossible to get out, so it's gotta go. I need to get the LS1 in there and I am not going to have a stupid piece of metal stand in my way!
Old 09-11-2005, 07:07 PM   #9
Z28Owner
Z28Owner's Avatar
I took a sawzaw to mine when I swapped to auto. Cut both bottom parts even with frame, cut whole xmember in half, then used a jack to raise boht parts up far enough to get the sawzaw in to cut the other sides. You will need all the room u can so cut it as close to frame as you can.
1971 LWB Chevy C-10
350/350 3:42 eaton
Z28Owner is offline   Reply With Quote
Old 09-11-2005, 09:58 PM   #10
chevymad
Even after torching and beating out all the rivets.. with the cab off.. I still had trouble getting the xmember to come out of the frame. Since i didnt think I'd ever need a 3spd xmember, I cut the thing in 2 and threw it in the scrap heap.
chevymad is offline   Reply With Quote
Old 09-11-2005, 10:46 PM   #11
shifty
Questionable
shifty's Avatar
I'm ready to toss mine in. I'm going to finish cutting it even with the frame tomorrow. I think I'm just gonna leave the pieces in there until I get the truck to the point I can start doing a frame-off.
Old 09-13-2005, 01:08 AM   #12
shifty
Questionable
shifty's Avatar
i found a shortcut tonight in my frustration. using an air hammer with a chisel bit, no matter how sharp, totally sucks, you just peel the rivet back slowly and i've only got an 11gallon tank, so i pound for 15 seconds and the tank has to refill. sucks ass.
here's the shortcut - i got it out in less than 90 minutes.
take a sawzall, cut the center of the xmember out. then cut the top and bottom of the xmember within an inch of the framerails (you'll need that overhang later). after that is done, sawzall the rivet heads off the top and bottom of the framerail (it's 100 times faster than grinding them).
Once you got the rivet heads off, beat the last pieces of the xmember out with a BFH and it will pull the rivet with it.
Here are some pictures of the damage I caused tonight. Got a couple of minor nicks in the frame, but nothing that I can't fix later when I do a frame-off.
Old 09-13-2005, 06:58 AM   #13
70short/step
Sawzalls are Great!! Arent they!
70 Short/Step
Old 09-13-2005, 08:56 AM   #14
motocrosschump
Best tool ever invented
2006 Titan SE Crew Cab Daily Driver
2005 Mazda Tribute (Wifes car)
1969 C10 SWB 350/3 Fleet "Max"
1969 Chevelle 2 door 350/3
motocrosschump is offline   Reply With Quote
Old 09-13-2005, 09:25 AM   #15
CPNE
Resident Curmudgeon
CPNE's Avatar
Guess you gotta work with the tools you got. My suggestion is get an oxy-acetylene torch, 3 pound hammer, set of punches, and a cold chisel. When you get good with the smoke wrench you can cut the heads of the rivets off without hurting the frame, then heat around the rivet hole to expand the metal for easy removal with the punches and chisel.
Takes way less effort/time and you don't have the carnage and trashed frame parts you see here. Plus the skoke wrench works wonders on all kinds of rusted and hard to remove fasteners. Once you've used heat you won't go back. Sawz-alls are good for quick amputations of rusted sheetmetal as seen here.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
