Old 09-11-2005, 08:09 PM   #1
b454rat
400 or 468??
I have a choice between these two motors. The 400 is all stock, needs some work, but will require the least amount of work to put in my suburban. The other motor is a 468 that is in my car. I want to sell my car with the motor, but no takers yet. The motor is pretty radical, alum Bowtie heads, big cam, RPM intake, 10:1 comp. If I would put it in my burban, I would change the cam to a smaller one, like the Xtreme Energy 268. Had one in another 454 in my old truck, and it worked good, and sounded good. I have the crossmember off 73-87 style, so the mounts are no biggy. I would move it forward some to clear the valvecovers and HEI. Not sure how big my radiator is, but i would probly have to get a bigger one. Bout all I would need is headers, but that isn't even a big deal, less than a $100 down to Autozone or Advance Auto. The thing is, is I want to drive this truck, it's 4wd, but not gonna take it wheeling. Don't want a racetruck, either. Gonna swap in the 4-speed soon, and I pick up my axles tomorrow. Going from D44/D60 with 4:10s to D44/12B with 3:08s. With the 468, it's in my car and ready to go. I already have the flywheel, so just need a clutch. I liked the last 400 I had in my old truck, and wanted to build this one identical to that. I'm in a toss up to which motor I want to run. The way gas is, I want the 400, but with the 468 I wouldn't really need a gas pedal, could just let the clutch out. In the long run, it will be a hauler, want to get a camper for Bloomsburg, and the weekend outings or whatever. But either motor will easily handle that. I have pics of the 468 in the pics link in my sig, and would stay like that, except for an alum water pump and the v/c's will be red. Look just the like the motor in the background in Trucks. Red block and v/c, everything else aluminum. So what would you do???
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 6” lift
1999 GMC Yukon 350/4L60 4" SAS
Old 09-12-2005, 02:33 PM   #2
Frizzle Fry
Frizzle Fry's Avatar
Economically speaking I think the 468 will add more value to your Burb than it adds to your Malibu from a re-sell point of view. You don't see very many 60-66 trucks, let alone Burbs with BBCs. From a performance standpoint, Burbs are heavy rigs and can use all the help they can get. 400's are very capable, but if I was faced with that choice, I'd go with the 468 in the Burb.
Frizzle Fry is offline   Reply With Quote
Old 09-13-2005, 05:01 PM   #3
b454rat
I said when i first got my malibu that I would NEVER sell it, got to almost to where I want it, now i want to sell it. Go figure. I'm getting kinda tired of cars in general, everyone has one, but nobody still has a malibu, let alone one with a BBC in it. I can still find these cars around, but I've never seen a suburban like mine around here. I was in the military and got to travel alot, and the only place that I've seen some was when I was in Colorado. Like you said, I could sell the burban alot easier than the Malibu. And actually, my suburban isn't really that heavy, maybe cause I've used to my 97, which I think weighs 6500#. Hopefully I can get some pics of the process......
Old 09-15-2005, 01:45 AM   #4
speedking
Dude-go with the 400,and spare the rod...
Speed
-57 GMC 1/2 ton longbed,Pont. 400,4 speed
-62 Chevy 1 ton duallie,Chevy 355,4 speed
-66 Pontiac Catalina 2 dr. hardtop,389,T-400
-81 Ford Fairmont wgn.,2.3,4 speed
-68 Triumph TR6-R 'cycle,various mods
-66 C-60's back
-there's probably others...
speedking is offline   Reply With Quote
Old 09-15-2005, 12:09 PM   #5
toroflow
I had a 454 in my 1960 GMC Sub 4x4 and pulled it out and sold it due to the horrible gas mileage....I mean, I don't expect it to get 15 MPGs, but at 8-10 it sucked....besides, I have a 454 dually crewcab 4x4 to tow with, so it didn't make sense to keep that gas hog 454 in the Sub. I would stay as small as you can (cubic inch wise) and save your wallet at the pump!!!
Ken
'60 GMC 3/4T 4x4
'60 GMC Suburban 4x4
'64 GMC Suburban 4x4
toroflow is offline   Reply With Quote
