Old 09-12-2005, 09:32 AM   #1
rivernut
Car 4 speed?
Ok, Dumb question of the day. Can a regular muncie or gm 4 speed from early camaro's, chevelle's, nova's, be made to fit in 2 wd trucks. Thinking about that with a 402 in my 72. Thanks.
Ps. modifying mounting brackets isn't a big deal for me, if needed. Also has it been done (I'm sure it has to have been with this bunch) and are there any pictures.
Rivernut
'72 1/2 ton 350 auto
rivernut is offline   Reply With Quote
Old 09-12-2005, 10:06 AM   #2
gr8scott51
gr8scott51's Avatar
Anything will fit if you use a big enough hammer.
The shifter will be in the middle of your bench seat. Got bucket seats? I'm sure someone makes a relocator for the linkage. That's why most truck manual transmissions are top loaders.
Silence is golden, duct tape is silver. - Scott
gr8scott51 is offline   Reply With Quote
Old 09-12-2005, 10:10 AM   #3
chevyguy_72
Vintage Evil
chevyguy_72's Avatar
I use to have a camaro 4 spd in the truck. It is not Heavy Duty enough to handle the weight. I went through 3 of them before i went back to a TH350.
It fit fine. Might have to adjust the length of the drive shaft.
Current Rides:
Vintage Evil - 72 Chevy C10 (Always a work in progress) Vintage Evil Build Thread
EvilK5 - 71 K5 Blazer
Evil Twin - 2006 Suzuki M109R
EvilDmax- 2018 GMC 2500 Denali Duramax
chevyguy_72 is offline   Reply With Quote
Old 09-12-2005, 03:35 PM   #4
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
We have a Muncie M22 behind GM's 290 HP crate motor in my sons truck and its lots of fun. Using the Mr. Gasket Truck shifter, there’s no problem hitting the seat; however we do have the buddy buckets.
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is online now   Reply With Quote
Old 09-12-2005, 05:10 PM   #5
acloco
Any of th M20 (LARGE counter shaft shaft -...no..did not stutter - heavy duty has 1" counter shaft shaft), M21, or M22. Or...T10's will work. Avoid Saginaws...for anything with HP or torque...you will tear them up.
Hurst has a competition Plus shifter that works with a bench seat....with no problems.
acloco is offline   Reply With Quote
Old 09-12-2005, 07:35 PM   #6
Boog
laying low
Boog's Avatar
You'd be surprised how the Muncies just bolt right in. I put a Muncie close ratio 4 speed in my 78 Chevy truck that came from a 69 SS Nova. Bolted right in, input and output shafts were of the same size and spline counts as the stock truck 3 speed so the clutch and driveshaft yoke were correct. Tranny length was the same. I had mine swapped out in under 2 hours including cutting the hole in the floor for the shifter. Drove that one like that for 6 years.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 09-12-2005, 07:42 PM   #7
pissonNOS
senior member
pissonNOS's Avatar
I agree about the saginaw statement i had mine in my 307 and i just put another one in, but I absolutely bagged on the first one I had and it only failed because I tried doing a reverse burnout and broke a bunch of ****. But ya the conversion is really and i used the hurst shifter and it works great with a bench seat.
Jason
69 GMC bagged
pissonNOS is offline   Reply With Quote
Old 09-12-2005, 10:13 PM   #8
KEH
Better late than never
KEH's Avatar
Yes, avoid the Saginaw. I have had mine rebuilt twice and it has gone down again.
A buddy was just telling me that years ago he mounted a 3 speed overdrive tail housing to a 4 speed and made a 4 speed overdrive. I have not heard of that, but it sounds like a good deal. Anyone done that?
1970 C/10 SWB Stepside
KEH is offline   Reply With Quote
Old 09-12-2005, 10:31 PM   #9
68C15
blood type; Retumbo
68C15's Avatar
HEY, that sounds like the perfect combination for my stepside with the caddy mill. any info guys?
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 09-12-2005, 10:38 PM   #10
acloco
The overdrive is extremely on the thin side of life. Definitely will NOT hold up to a Caddy mill with all that torque. In fact, they were never installed, from the factory, in anything bigger than a 283. Sorry dude.
Old 09-12-2005, 10:58 PM   #11
pissonNOS
senior member
pissonNOS's Avatar
just wondering if you could tell me where he got this rebuilt and what parts were replaced because when I tried to rebuild my last saginaw I was told there is no such thing as hard parts for these saginaws anymore, so I had to buy a rebuilt one that was done about 5 years ago. Sorry for hijacking your thread also
Jason
69 GMC bagged
Old 09-12-2005, 11:09 PM   #12
acloco
They are around...just have to find a shop that specializes in manual transmissions.
gears4less? Something like that.
Ask the companies that rebuild larger truck manual trans....they have the info.
Old 09-12-2005, 11:45 PM   #13
jimfulco
Saginaw overdrive conversion:
http://www.chevytrucks.org/tech/overdrive.htm
A few hard parts, along with rebuild stuff & ID info can be found at
http://www.dandltransmission.com/saginaw.html
or you might find something at www.kajunjon.com
jimfulco is offline   Reply With Quote
Old 09-13-2005, 12:11 AM   #14
jhwkns
Registered Cruiser
jhwkns's Avatar
I've had good luck with my Saginaw four speed. Saginaw parts
I intend to live forever. So far, so good.
jhwkns is offline   Reply With Quote
