Old 09-12-2005, 09:45 AM   #1
CG
BlahBlahBlah
68 vs 72 doors
i believe i know most of the differences between the two doors. im wondering if you replace the complete 72 inner door mechanics with the one from a 68 will the 68 door panel then match up to the indentation of the 72 door?
Old 09-12-2005, 12:32 PM   #2
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Yes I have swapped inner door guts from 71 and eariler to 72 doors and the only problem is 72 door pannels will rub the window crank because of the difference in shaft lenght...Therefore you have to run the earily door pannel's..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 09-12-2005, 08:08 PM   #3
Low69CST
72 has an extra screw on the inside under the wing glass area. Not sure if that will create a problem or not.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
