Old 09-12-2005, 10:35 AM   #1
76bonanza
76bonanza's Avatar
lowering question
I just bought a 68 with 3 inches in front and 4 inches in rear. springs in front and blocks and springs in rear.
Question is it sits about 1/2 to 1 inch lower on drivers side front and rear and when you sit in it it really squats on drivers side Is this from cheap shocks or is it just broke in on driver side more about 7 months on lowering and only driver has ever been in it.
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 09-12-2005, 03:00 PM   #2
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Not sure if your body mounts or your springs are your problem but shocks wont have any thing to do with the ride height.Unless they are to short and are bottomed out on the up travel
sneakysnake is offline   Reply With Quote
Old 09-12-2005, 03:48 PM   #3
Frizzle Fry
Frizzle Fry's Avatar
Put it on a level surface and jack the rear-end with the jack under the diff. Once both rear tires are off the ground, look at the rear-end relative to the frame and take various measurements. Remember if you don't have an adjustable panhard bar the rear end is off to the right, so don't let that throw you off. Check the front with it jacked this way too. You should be able to determine if the problem is in the front or rear using this method. If I had to guess, I'd say it's probably a spring issue. Check the rear U-bolt nuts too.
Frizzle Fry is offline   Reply With Quote
Old 09-12-2005, 04:34 PM   #4
chevjayfsd
Project 7dos
chevjayfsd's Avatar
Could it be the infamous Chevy Lean?
7DOS - 1972 C-10
350/350
Porterbuilt/Accuair
20x8.5/20x10
Ride Low or Die
PSSST - Yes it's bagged.
7dos build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=610290
chevjayfsd is offline   Reply With Quote
Old 09-12-2005, 05:10 PM   #5
76bonanza
76bonanza's Avatar
frizzel what do you mean off to the right? I dont think the bar is adjustable it is higher on the passenger side and when I sit in it it really leans. The body mounts and spring are new but dont know what kind they are.
Also if the spring were new and the 200 pound guy was the only one in it driving it for a few months could the springs just be settled more on that sied?
What is the chevy lean?
1968 c10
lowered 3" 4"
Old 09-12-2005, 05:46 PM   #6
chevjayfsd
Project 7dos
chevjayfsd's Avatar
If you look at most Chevrolet trucks, new and old, they are all leaning one way or another, if you see a 67-72 parked at the mall, go measure both sides and you will get a diff. measurement...
Thats in most cases
Jason
7DOS - 1972 C-10
350/350
Porterbuilt/Accuair
20x8.5/20x10
Ride Low or Die
Old 09-12-2005, 05:47 PM   #7
tomatocity
tomatocity's Avatar
I agree with Frizzle Fry. If that does not work try disconnecting anything that can limit the travel of your suspension. You can disconnect the panhard bar and shocks, one at a time. If this does not work it could be the trailing arms. loosen and re-torque anything of the suspension anchor points.
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck.
tomatocity is offline   Reply With Quote
Old 09-12-2005, 06:02 PM   #8
Frizzle Fry
The rearend will be off-center to the right on a lowered truck with a stock PHB, so if you measure from the tires to the wheel arches this will have to be factored in. It shouldn't sag that much on one side.
Edit: Just measure a the bump stops
Old 09-13-2005, 07:33 PM   #9
Rdrdave
Broke and still trying
Rdrdave's Avatar
does it have a sway bar in it? If not, it has ...a** lean. Means your heavy a** is making it lean!
Rdrdave is offline   Reply With Quote
Old 09-13-2005, 08:03 PM   #10
76bonanza
76bonanza's Avatar
I dont think so they did not come stock did they? The sway bar is the one in the front right?
1968 c10
lowered 3" 4"
Old 09-13-2005, 11:08 PM   #11
Rdrdave
Rdrdave's Avatar
Some/most came with a front sway bay. Yes it is in the front. Mine didn't have one and it was always slushy feeling. Threw on a 1.25 and wow what a difference.
