Finally a Bulldawg
Air Cleaner
Will a 14" Air Cleaner fit on a 307 4bbl with an HEI Distributor? I have a 14" one but the intake and carb are off the truck now so I can't just walk out and test it. I wanted to know if anyone's had problems with fitting 14" ones on their trucks because I hope to have this thing put together on the 4th
Is the air cleaner base a drop base or flat base? If it is drop base you might need a plastic spacer that is made by transdapt or edelbrock, and can be picked up a local schucks, kraggen, checker or local parts store. If it is flat you shouldn't have problems even with your HEI.
This is only my opinion and it is subject to change. 70 GMC Short box stepside Blown 388 Stroker 72 K/5 Blazer 350/SM465/205 |
Finally a Bulldawg
It's a drop base. I'm actually taking it back today because it's just a little too big for my Edlebrock carb. I was either gonna pick up another 14" Edlebrock cleaner or just go for a 10" one instead. They're suppose to fit my carb.
I wouldn't take it back and get a 10". The 14" will fit just fine, as long as it is a 4bbl Edelbrock or similar carb. A 2bbl will need a adapter to make it work. You should be able to run 4 or 5 inch tall filter without any problem. You will be fine.
its all about the +6 inches
The 14 inch dropped base WILL need the spacer if it is a performer carb. That's what i am running.
Plus it says it right in the book. |
Finally a Bulldawg
well, I just took the 14" back today and got the 10" one. It came with a 2" tall air filter but I'll probably change it out for a taller K&N filter. This way I know for sure that it'll fit.
