Old 09-12-2005, 10:09 PM   #1
bigblockc10
bigblockc10's Avatar
Question Frame swaps
I don't know if this question has come up before I would assume it has but I'll ask anyway if it has maybe you can direct me to the thread.
Okay here goes I have a 70 swb stepside that I am back-halving I am wondering if it is possible to use a chevy S10 frame as a start for reasons of availabilty,price,newer technology etc.etc.
I realize fabrication would be required which is no problem I have all the cool toy's to do such work(plasma cutter,Mig welder,frame jig) I was wondering if it would be worth the effort has anyone done such a swap I know the older trucks have done such a swap.
Any input good or bad would be appreciated.
Thanks for a great site
1970 C10 Stepside (soon to be a 68
w/PS/PB/S&W back-half narrowed F**D 9inch w/Discs)
66 427/435 corvette motor (hopefully 871 Blower)
66 M21 4 speed (swapped in a built TH400)
31/16.5/15 Mickeys (soon to be 29.5X18.5X15 MT)
1972 C10 Stepside Pro-Street
1988 bed
3" Top Chop
Custom Red Pearl paint w/overlapping Ghost Flames
P/S P/W P/B P/DL P/door open
Everything Shaved
Frenched antenna
461CI BBC BDS Blower 1100 Dynoed HP
TH400 Super Heavy Duty
Full Back-Half
Narrowed 12 Bolt 4:10
bigblockc10 is offline   Reply With Quote
Old 09-12-2005, 10:52 PM   #2
Stroker
I would think the stock trailing arm suspension properly set up would be better than what the s10 could offer, but I'm no expert in the suspension field. I've seen pic posted with the front wheels in the air using basicly a stock rear suspension with coil overs. I believe a 14 inch wide tire will fit with some tubbing and the right offset.
72 SWB parts and pieces
Oklahoma
Stroker is offline   Reply With Quote
Old 09-12-2005, 10:59 PM   #3
bigblockc10
Yeah I saw trhe same pic's.
However I am backhalving anyway 4 link narrowed F***d 9 inch coil over yada yada.
I just need or want a newer front suspension set-up without going the custom route.
Does this make sense or am I out in left field way out!
1988 bed
3" Top Chop
Everything Shaved
Frenched antenna
Full Back-Half
Old 09-12-2005, 11:09 PM   #4
bigblockc10
frame swap
Oh forgot to mention new tires are 28.5X18.5.
Got them brand new with new polished centerlines skinny's for the front for 300.00 from a street rod buddy took them off his TBucket he went old school steels and moon caps.
1988 bed
3" Top Chop
Everything Shaved
Frenched antenna
Full Back-Half
Old 09-12-2005, 11:25 PM   #5
milehightoyz
AttentionDeficitDisorder
milehightoyz's Avatar
i dont know if this would be of any help to you or not but i used an s-10 front frame stub and rearend under my 58 chevy shortbed. my initial intention on using the s-10 stub rather then the typical camaro/nova subframe was that there were tons of inexpensive and easy to find parts available for them (ie, drop parts, air suspension etc.) as you may already know the s-10 frame is far narrower then the fullsize truck frames which make them look a little goofy. i wanted this look prolly for the same reasons you do, because i wanted really wide wheels. i was going for a "slammed dub city" style truck with 18x10s on the front and 20x12s on the rear. i would make up the difference in frame widths with reverse backspacings on ym wheels giving me huge wheel lips on front and rear. here are a few old pics too show you what i mean, that is an 18x0 on front with 5" backspace and there is still tons of space bewteeen the wheel outer lip and the fender. anyway in the end if i could do over i would probably not use s-10 stub and go with the camaro/nova subframe instead.
here are some old pics of the truck when i first started on it, that is a stock s-10 front end before any drop parts were installed. this is a front pic to show how wide of a wheel you can fit up fornt with gobs of space still for more. that is an 18x10 with a 295/45/18" tire and 5" back space on the front and a stock tire next to it.
Side pic to show 4" lip on the wheel:
Profile pic:
milehightoyz is offline   Reply With Quote
Old 09-12-2005, 11:26 PM   #6
milehightoyz
p.s. since you are getting backhalved anyways, why not just throw a 73-87 crossmember under your front end?
Old 09-13-2005, 12:26 AM   #7
Stroker
OK, now I understand what your doing. I was thinking you where planning to use the S10 frame as back half on the 70. I don't know of anyone using the S10 frame under the 67-72s. If you go for it be sure to take pictures as you go. I'de like to know how it works out.
BTW the 58 looks Cool.
Oklahoma
