Old 09-12-2005, 11:56 PM   #1
Brian Ringer
Junior Member
Brian Ringer's Avatar
lever on rear diff?
I just got a 86 3/4 ton burb and I went to go replace the hard brake line going to the rear and it goes into a junction that looks like it controls a lever going to the rear diff. Can someone tell me what that lever going to the rear diff may be.
Brian Ringer is offline   Reply With Quote
Old 09-13-2005, 12:02 AM   #2
edman87
junk collector
load based proportioning valve- not the thechnical term, but you know what i mean
lets more brake line pressure to rear if there is a load
'87/89/76 K5 in progress
'99 K2500 short crew
'91 camaro rs
'98 jeep tj
'52 willys cj3a
edman87 is offline   Reply With Quote
Old 09-13-2005, 05:22 AM   #3
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I was going to ask the same thing! It's on my 89 3/4 ton burb. Is this part of a "towing" package? My burb has a power steering cooler, oil cooler, tranny cooler, TH400, 4.10 gears.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 09-13-2005, 09:55 AM   #4
Brian Ringer
Junior Member
Mine also has the th400 with the tranny cooler not sure about the other things mentioned. I was told though that it did have the factory tow package. Thanks guys!
Old 09-13-2005, 09:56 PM   #5
edman87
junk collector
not sure of the tow package question, but many compact trucks have this also. I had a 2wd base model mitsubishi that had it and my k2500hd has it too, it might vary by manufacturer as to whether or not these were installed.
'91 camaro rs
'98 jeep tj
'52 willys cj3a
