09-13-2005, 12:35 AM | #1 |
Mystery Fluid?
I was looking under the hood tonight when I noticed on the passenger side intake on the gasket there was a shiny substance on the intake manifold gasket on the passenger side on the exhaust port. It doenst smell like oil or coolant. Not very much of it, I wiped it off with my finger but I got no idea what this is. Anyone have any ideas. A little history the intake is a edelbrock 2101 and I swapped the gaskets 2 months ago.
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
09-13-2005, 01:10 AM | #2 | |
Having issues
Quando Omni Flunkus Moritati. The Man's Prayer: "I'm a man, but I can change, if I have to, I guess." |
09-13-2005, 01:15 AM | #3 |
I did that and then drove it again. It came back..
09-13-2005, 08:07 AM | #4 |
Sometimes oil will come around the intake bolts. You may want to put some locktite on the threads and see if it comes back...
Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 |
09-13-2005, 08:15 AM | #5 |
the intake bolts should be installed using a quality thread sealant
09-13-2005, 08:38 AM | #6 |
67-72 Addict!
Maybe gas leaking from carb???
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
09-13-2005, 05:13 PM | #7 | |
09-13-2005, 05:21 PM | #8 |
you have an AC?
2006 Titan SE Crew Cab Daily Driver 2005 Mazda Tribute (Wifes car) 1969 C10 SWB 350/3 Fleet "Max" 1969 Chevelle 2 door 350/3 |
09-13-2005, 05:22 PM | #9 |
soak it up with a dopper and try to ignite it. if it doesn't ignite then its a form of water
09-13-2005, 05:28 PM | #10 |
Are you running straight water?
09-13-2005, 05:57 PM | #11 |
No ac. Running 50/50 coolant. Will try the dopper and see if it lites up.
09-13-2005, 06:03 PM | #12 |
What are your fluid options?
*water *oil *coolant *freon/oil *power steering *transmission *windshield washer *brake fluid **KYJelly when you installed the HEI
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck. |
09-13-2005, 06:16 PM | #13 |
JUNK COLLECTOR!!!!!
headlight fluid?
baby The dark side! 2000 XLT PSD F-250 4x4! Offroad package 1970 C10 Short-step soon to be short fleet, maybe? Corvette in truck's clothing in work! Corvette IFS, IRS, TPI and Doug Nash 4+3 |
09-13-2005, 06:18 PM | #14 |
'69 Step
vacuum advance paste is my guess
09-13-2005, 06:30 PM | #15 |
Hahhhahha
09-13-2005, 06:51 PM | #16 |
Franko72
did you use sealant? What kind? maybe you got the waterd down batch. Dont think so!
Sodium silicate will look shiny or glycerin will also.
1972 C20 cheyenne Super 402 BB/400 turbo LWB A/C Tilt, Cruise Control, Saddle tanks, Tach My Home Page Better to burn out than it is to rust |
09-13-2005, 07:38 PM | #17 |
Forgot to add that I also changed the passenger side valve cover and gasket.
