Old 09-13-2005, 05:03 AM   #1
Mcgwirejh
Whats the bigest size tire i can run?
I have a 1982 chevy 1/2 4x4 i got 33's on it right now and just got done putting a Tuff Country 6 inch lift on it and theres a huge gap the 33's kinda look small could anyone tell me whats the bigest size i can rund without triming fenders or anything.
Mcgwirejh is offline   Reply With Quote
Old 09-13-2005, 05:09 AM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
without any interference with the fenders during flexing, a 36" tire on a 10" wide rim with at least 3.5" of back spacing. You could probably run 37-38s on a narrower(8") rim. if you go with 12-14" wide rims I'd say keep it at 35". Of course this is all subjective and I'd recommend test fitting if possible before buying, I have a neighbor running 35s BFGS w/ 6" of lift and he had 38.5s TSLs that would occasionally rub.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 09-13-2005, 05:11 AM   #3
Mcgwirejh
yeah b/c right now i have 33x12.50 there on 15x8's chrome mods not sure what the backspaceing is though thinknig about a 10 inch rims at the most I'm new to this lift stuff thanks.
Old 09-13-2005, 06:13 AM   #4
Mcgwirejh
heres another ? i found some rims i wanna buy at summitracing they are 15x10 says the back spaceing in 4 in so then the bigest tires i could clear with them rims would be 36x12.50 right
Old 09-13-2005, 07:31 AM   #5
Pretty much.Most tires you`ll find will be 35"radials.There`s a few 12-12.50 x36 tires out there.Basically,you can run these tires on 10"rims which will all be somewhere around 4" backspace.
