Old 09-13-2005, 01:28 PM   #1
5150
C10 Club Tennessee
5150's Avatar
On the Dizzy...Which one is the number 1?
Hey guys,
This is my stupid question of the day. I've been touching up under my hood and I replaced the wires after paint. I have my Haynes Manual and going by that the number 1 on the dizzy is the first peg to the left beside where the ignition coil comes out(HEI). But I can't get the truck started now so I must have it wrong.
thanks,
Bryan
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 09-13-2005, 01:33 PM   #2
shifty
Questionable
shifty's Avatar
If you haven't pulled out your dizzy, #1 always will be the one pointing towards the number one cylinder.
If you have pulled it out, you get the pleasure of resetting the timing
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 09-13-2005, 01:36 PM   #3
5150
C10 Club Tennessee
5150's Avatar
I just pulled off the cap. I'll try it again.
Bryan
www.gmtruckshow.com
Old 09-13-2005, 01:50 PM   #4
CPNE
Resident Curmudgeon
CPNE's Avatar
Assuming a V8...
You do realize that there is the firing order to consider as well. It does not go 1-2-3-4-5-6-7-8 clockwise around the dizzy. Clockwise it goes:
1-8-4-3-6-5-7-2
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 09-13-2005, 01:54 PM   #5
tomatocity
tomatocity's Avatar
#1 should be between #8 and #2. Follow the #1 spark plug wire from the #1 spark plug to the distributor cap.
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck.
tomatocity is offline   Reply With Quote
Old 09-13-2005, 03:10 PM   #6
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
A pic
sneakysnake is offline   Reply With Quote
Old 09-13-2005, 03:17 PM   #7
sneakysnake
If you didnt pull the dist.
pull the cap, pull #1 sparkplug turn engine over until #1 compression stroke, look at rotor see which one its point to.
any one of them can be #1 if someone time it to be.
Old 09-13-2005, 03:24 PM   #8
ante_up13
My hei looks different than the one in the Haynes manual. My #1 goes in the dizzy forward of where the engine wiring harness and tach harness hooks up( box shape with battery + and - signs along with tach on there). On the rearward side of the little box terminal or whatever its called should be the #2. Hope that helps.
ante_up13 is offline   Reply With Quote
Old 09-13-2005, 03:30 PM   #9
5150
C10 Club Tennessee
5150's Avatar
Here's a pic of my dizzy. I still can't get it started. This pic is actually after I rotated all the wires one over just in case I was off.
Bryan
www.gmtruckshow.com
Old 09-13-2005, 03:48 PM   #10
extd56
extd56's Avatar
Take the number 1 plug out, crank it over until you get compression coming out of the hole, and make sure that you can see the timing mark on the pointer, I set mine at 8 degrees. Your rotor should be pointing where you have your number 1 plug wire. If not you need to move it. Make sure you have all the wires in the correct order and that you have 12 volts going to the distributor and that it is firing.
extd56 is offline   Reply With Quote
Old 09-13-2005, 03:55 PM   #11
Frizzle Fry
Frizzle Fry's Avatar
Put your finger over the SP hole and have someone crank it a little at a time until the compression blows your finger off the hole. Let it crank over a few times so you feel the difference between the exhaust and compression strokes. Then line the cap/wires up so that wherever the rotor is at when your a about 1/2 way into the compression stroke is #1.
Frizzle Fry is offline   Reply With Quote
Old 09-13-2005, 04:51 PM   #12
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Man oh man Brian, your luck is just plain bad lately, hope it all works out
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 09-13-2005, 05:43 PM   #13
5150
C10 Club Tennessee
5150's Avatar
I got to go to work now, still not running. Don't laugh at me when I ask this question. When I painted the motor and firewall and all I left the plugs in. I don't have the funds right now to get new plugs, but would the paint on the end of the plugs have anything to do with it?
Also the hot wire to the dizzy is going the far left slot. When I put it on the other 2 slots I got a little bit of a pop
Bryan
Bryan
www.gmtruckshow.com
Old 09-13-2005, 06:20 PM   #14
hilljob26
hilljob26's Avatar
mine is where you plug in the coil wire,in the front of that,should be the 3 rd one around from that part going forward,thats just how mine is,it actaully looks like the plug on the top of the cap points at #2,but that is my #1,i tried going to the 2nd one,but that didn't seem to work,if you look at the diagram above in the other post,my #1 is that #8,if that helps
21 2500hd duramax
58 apache
HILLJOB GRAPHIX--for all your graphic needs
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=542497
LS ENGINE SWAP INFORMATION THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=377348
4l60 to an NP205
http://67-72chevytrucks.com/vboard/s...43#post3697343
hilljob26 is offline   Reply With Quote
Old 09-13-2005, 06:46 PM   #15
69 longhorn
#1 TDC compression stroke....thats all you need to know. after that, you can dump that dist in any old way you want......just make sure you start #1 wire where the rotor is pointing, & you have it "hooked up"! The book puts the wires in 1 spot just for tuneup specs Best of luck..... L
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 09-13-2005, 09:20 PM   #16
guyryan100
guyryan100's Avatar
If the paint on the ends of your plugs prevents the bare metal from showing, that's part of your problem. You need to get all that paint off so the metal of the plug makes really good contact with the metal inside the plug wire.
Also, don't try to line it up by putting the #1 wire in a particular position on the distributer - what matters is that the rotor under the cap is pointing at your #1 wire when the #1 cyl is all the way at the top. That could be on the back of the dist. or the side or anywhere as long as the two line up. And once those are lined up you can plug in all the other wires relative to the #1. So after your #1 plug fires the distributer rotor will keep turning and point to the #8 wire, etc.
guyryan100 is offline   Reply With Quote
Old 09-13-2005, 09:21 PM   #17
masterbeavis
Having issues
masterbeavis's Avatar
Bryan
Yes.
Take a rag soaked in carb or brake cleaner and clean the paint off of the tips. Wont hurt anything to try. Also, take a looksie on the cap, it will tell you which prong to plug the hot wire into. (B+/tach) You should test it for 12v while you are at it. While cranking it will drop some, to 9V maybe
Quando Omni Flunkus Moritati.
The Man's Prayer: "I'm a man, but I can change, if I have to, I guess."
masterbeavis is offline   Reply With Quote
